Have I screwed up my "towing" truck?
Old 03-28-2007 | 09:59 AM
jeeptjstud's Avatar
I just removed my 100hp injectors to install 180-200hp injectors.....And now I am looking at a turbo upgrade. I have done alot of research on here but dont know if I have screwed up my towing ability. I am going to purchase a sledpuller66/14. Can I tow with my current setup? Im actaully thinking of taking my truck back to 100hp sticks
Also.....I just towed my wifes grand cherokee and it actully pulled really well with the comp off with the injectors and stocker turbo.
Old 03-28-2007 | 10:06 AM
chop342's Avatar
From: Climax, MI (between battlecreek and kalamazoo)
Well you can tow with just about anything, just expect some noticable turbo lag with that setup. But it is possible.
Old 03-28-2007 | 10:07 AM
Gotlift01's Avatar
You are going to get toasty!! I'd do just as you did for the time being.....and when ever you tow turn the COMP off! You'll still probably get warm, but you should hopefully be able to control it.
And I'd go with something a tad bit smaller on your new turbo....a 66 is going to pretty laggy unless you don't mind boost lag. A Phatshaft 64 would be a good choice. JMHO
~Nick
Old 03-28-2007 | 10:16 AM
Mike D's Avatar
You should be able to tow. Not too sure about the turbo choice. I've towed pretty heavy with my setup and have done just fine. You'll have to lock out O/D on steep grades.
jeeptjstud's Avatar
I posted on here before I bought the 180hp injectors and the consensus was a 66/14
maybe thats wrong????
Old 03-28-2007 | 10:19 AM
mcoleman's Avatar
I tow with my Sledpuller 66 every weekend but not in the mountains. I leave the TST on #3 and it is stacked with an EZ. And it runs just fine unless you get stuck below 1600 rpm or so in OD and have to downshift to get the rpms back up. It gets a little smokey at low rpms in OD.
Old 03-28-2007 | 10:27 AM
jeeptjstud's Avatar
hey mcolman, how much weight do you pull??? how is the lag?
tchdodg
08-01-2012 12:08 PM
PEAKSTRYDE
10-11-2007 05:20 PM
Bikinaz
07-31-2007 10:43 AM
Lardog
07-13-2006 07:42 AM
duallydave
11-04-2005 09:14 AM
