Have I been "misinformed"?
Originally Posted by Don M
1800 degrees suggests the timing is not fully advancing. Its as typical problem with the VP44 when theya re getting tired. The newer pumps use a better material pressed into the pump housing to help avoid the trouble. This would not have anything to do with the starting or idle though.
Low Dyno numbers also indicate a pump problem. Either pressure loss through wear, timing solenoid or a combo of both.
Luckily nothing money wont fix.
Don~
Don~
"Luckily nothing money wont fix." I'm living this statement. Low HP? Nothing money won't fix. Trans not holding? Nothing money won't fix. Not enough air? Nothing money won't fix.
Originally Posted by Mcmopar
When will the pump be here? Sunday install?? I am doing the twins install on Sat. Are you coming down?
I'll let you know about the pump, I'm planning on coming down either way.
John P. highly suggests that I get a new pryo so, I'm tracking one down.
Originally Posted by HOHN
I like my NV series autometer....the new green faced lighting is nice, but bright.
jh
jh
I should have said pyro prob. It's on the way. I'm also going to test the old one. I have a buddy in the Instrument business, right Phil.
New pump is on the way, should have it tomorrow, if UPS doesn't mess up.
I was wondering................. If the pump is not perfoming correctly, why won't it throw a code? I would think I would get a check engine light or a 0216 code.
If I get the pump on time I should have in Sunday. I'll report back with the results.
I hated spending that kind of money, but the silver lining is, the FCM boards have been updated since 99.
Thanks for the help everyone.
Have a new one shipped to my house Sat. delivery.
I'm trying to get one shipped, but it's been SLOW going.
