Hardened head bolts instead of studs?
Old 03-10-2011 | 02:57 PM
Forkspear's Avatar
Anyone know anything about these hardened head bolts for a 12 valve? At $130 they are much cheaper than studs.
http://www.mightydiesel.com/store/pr...oducts_id=1011
Old 03-10-2011 | 06:48 PM
w250_93's Avatar
I used some regular bolts from a place like fastenal, they lasted through two years of 50psi before the head gasket blew an that was probably just because i never retorqued them lol. They were just a 12.9 grade
Old 03-11-2011 | 02:25 PM
HOHN's Avatar
Yes, and there's a reason they are so cheap.
First question: why are the Socket head instead of Hex Head?
Second: what material are they made of? Simply being class 12.9 only tells you how hard they are-- it gives you NO information about their strength unless they are class 12.9 per a given industry standard (DIN/ISO, etc) and correlated to a standard capscrew geometry.
You can easily make a cheap 1010 steel screw hard and brittle. It will have terrible fatigue performance (no ductility) and will fail pretty early.
Harder is not always better.
Many grades of steel are prone to hydrogen embrittlement when hardened fully, and operated in a hot environment like the engine.
Save your money. These screws are a ticking time bomb for your engine.
Forkspear
03-15-2011 02:38 AM
sheriffav8r
03-03-2010 10:05 PM
Riflemanusmc
02-05-2009 11:37 AM
w250_93
01-24-2009 09:22 AM
cheapskate
03-09-2007 10:18 AM
