H2 rims
Old 01-14-2006 | 02:48 PM
AllPlay's Avatar
H2 rims
Could someone give some advice on H2 rims. How much opening of the center, and with what? Any other issues? Any pics on a 2nd gen?
Old 01-15-2006 | 11:22 AM
AllPlay's Avatar
So nobody's done this to a 2nd gen??? If it works on a 3rd gen why not on 2nd, can anybody think of a difference? You can pick up tires and wheels for around 400 bucks. Seems like a cheap why to get 17" wheels and 35" tires.
Old 01-15-2006 | 11:41 AM
P.J's Avatar
P.J
People have done it, just haven't chimmed in yet.
I don't want to qoute you the wrong #, I'm thinking 4.675" or something/
Do a search,
Old 01-15-2006 | 11:42 AM
P.J's Avatar
P.J
As crude as using a hole saw with a round cut out of wood to keep it centered, all the way to having them dismounted and done at a machine shop.
Old 01-15-2006 | 01:03 PM
JKM's Avatar
JKM
Loom up Joefarmer, he had H2 rims on bubbles IIRC.
Old 01-15-2006 | 06:58 PM
doodah's Avatar
If your lookin for a set, I got a friend in MN with a set for sale.... PM Me if interested
Old 01-16-2006 | 12:35 AM
Sea Bass's Avatar
I just did mine a couple of weeks ago.. I pretty sure the you want to open it to 4.77". Just measure your old rims. You'll have to modify the rear center caps also. I love mine. Can't beat it.
Oh yeah.. I was able to do mine on a Bridgeport without removing the tires. you just need to support rims with blocks and then clamp them down. It's not too bad really.
Doug
Old 01-17-2006 | 03:10 PM
Will Manchester's Avatar
I did a set about 6 months ago. I think I opened mine up to 4.772 or 4.774, can't remember. Like Sea Bass said, measure your original rims.
You definitely want to have these cut on a mill or a lathe. Make some phone calls to local machine shops, they should be able to help you out. The OEM wheels are hub-centric, meaning that they align themselves off the hub. You will find most aftermarket wheels are not like this! It works, however its just not 100% right. 2nd, and much more important, most wheel balancers will balance the wheel off the opening for the hub. If you use a Dremmil tool (or whatever), you'll never be able to properly balance the tires.
Old 01-17-2006 | 06:49 PM
AllPlay's Avatar
Thanks for all the input. I now need my income tax check to come in and I will have a set.
Old 01-17-2006 | 07:09 PM
mikmaze's Avatar
pretty sure will has it correct, 4.774 anh you will be ahppy with them and how good they make the ruck look.
Diesel Dave2
01-23-2013 05:46 PM
JMOS4
02-01-2012 08:59 PM
Mark Hodowanec
15
11-11-2004 09:50 AM
doodah
12-19-2002 01:06 AM
