h.o pump
h.o pump
im trying to get a little over 400 hp. I have 2 questions. First can i do this with an H.O stock turbo? Second, if i put 100hp injectors on will the H.O pump be able to support it or will it be a waste of time?
I have a 01 dodge cummins with a raptor 150, 5" exhaust, CAI, Edge comp. NV5600
I had a he35 and 100hp plus edge j/a and it worked, I'd suspect the turbo and injectors would be ok, but he would not know for sure unless he has pyro to monitot EGT
i don't see it listed, and it's probably too obvious, but you WILL need a clutch! if you tow or haul much, the larger turbo will make the drivability way better, EGTs will be less of an issue
Puke
05-22-2003 12:18 AM
amartinson
0
05-04-2003 01:55 PM
TPilaske
16
11-22-2002 08:15 PM
Haulin_in_Dixie
47
11-17-2002 09:30 PM
