Guages, Finally...
Guages, Finally...
Here is what I jsut ordered, maybe you'll be kind enough to tell me wether I did the right thing <br><br>17203 - Autometer 3 Guage Pillar $49.35<br>4344 - 0-1600* Pyro $121.58<br>4305 - 0-60 PSI Boost $42.85<br>4361 - 0-15 PSI Fuel Pressure $193.06<br><br>Overnight Shipping Included (Once it reaches the warehouse)<br><br>Thanks!<br><br>--Phillip
Re:Guages, Finally...
[quote author=Desert Diesel link=board=7;threadid=8450;start=0#81490 date=1040167395]<br><br>4361 - 0-15 PSI Fuel Pressure $193.06<br>[/quote]<br><br> I think that is kind of high for a fuel pressure gauge! What is so speciel about it?
Guest
Posts: n/a
I might be missing something here, but -- <br><br>0-15 on the fuel pressure gauge is kinda low. I'm idling at 16-17 with a stock set-up except for hi-flow banjo bolts. 0-25 might be better, especially if you're going to do any upgrading. If you peg the gauge constantly at idle, that's not good. <br><br>On the other hand, 0-60 is kinda high for a boost gauge, unless you're planning on putting fueling/timing boxes on it, defeating the wastegate, and upgrading the turbo. The stock HX35 is not going to sustain anything over 35 psi for too long. 0-35 might be better, if you're not planning on major bombing. <br><br>My humble opinion. <br><br>GP
I currently have an Edge Comp, and a 3.5" Straight Pipe. Next week I'm looking at propane, and plan on Injectors there-after. Maybe I'll do Injectors first.<br><br>I though ppl were running 32-35psi of boost normally, under average bombing, and as for fuel, it was 0-15 or 0-100 psi and that's the only choices autometer has.
I could go with a 4377. It's a 30PSI Boost/Vac Guage in a Full Sweep Elec. instead of the 0-60PSI Mech.<br><br>I haven't gotten price on the 4377 yet.
Guest
Posts: n/a
Well, if you're going to use drugs, boxes, and big injectors, go with the 60psi boost gauge. But think about that HX35 turbo. Ya, you can run 35 psi or more, but you're on the edge. <br><br>As for the fuel gauge, you may have to go outside of Autometer -- Westach or some other brand. I had to do that. <br><br>GP
I was hoping for all matching guages. <br><br>Are there any others out there that look like the Autometer Ultralites?<br><br>I know there is a cheaper line of Autometers that are Black/Black which might match better, but I can't seem to find the same guages in that line, not to mention I want quality guages.<br><br> ??? ??? ???
Guest
Posts: n/a
I think you're referring to the Autolite "Phantom" line (black on black). They have the same movements as the Ultralites, and are of the same quality. The difference is the brushed aluminum bezels, faces, and bodies. The Phantoms match well with the Westach fuel gauge -- not an exact match, but it looks alright. <br><br>Beyond that -- it's a tough problem. <br><br>GP
The Phantom is a white face, not black.<br><br>I do like the black bezel though!<br><br>I do not see any 2 1/16th" Guages on Westach's site. Will their 2" guage work in Autometers tripple A-Pillar?
quick1300r
05-20-2009 07:11 PM
Jturs
19
12-25-2007 01:33 PM
6speedcowboy
01-05-2007 05:47 AM
