Guage Pods
Guage Pods
Who makes a nice A-pillar pod for 3 guages, I have the tweeters on the A-pillar so I think it might be in the way. I would like one that is colored to match my dark grey interior. The only one I have seen is the black Auto-Meter ones.
Re:Guage Pods
As far as I know, every pillar pod will come in black. It is up to the owner to paint the pillar to match his interior. The preferred choice of pillars are AutoMeter.
Re:Guage Pods
Holycack,<br><br>I have the Autometer 3 gauge pod in my 01. My interior is also dark grey. The gauge pod from Autometer was so close to the color of the factory A-Pillar trim that I didn't paint mine. Can't tell the difference.
Re:Guage Pods
[quote author=thecatsfan link=board=7;threadid=15674;start=0#147429 date=1055183285]<br>Holycack,<br><br>I have the Autometer 3 gauge pod in my 01. My interior is also dark grey. The gauge pod from Autometer was so close to the color of the factory A-Pillar trim that I didn't paint mine. Can't tell the difference.<br>[/quote]<br><br> OK,,,,,,,,,, I been waiting for someone to admit to this! ;D Now I can say that I did the very same thing. I installed my gauges in the Auto Meter triple mount A-pillar with tweeter and had every intention of painting it after my install was all done. Once it was up there,,,,, it looked great to me. I've had lots of people look at the set up and nobody has noticed yet. Even when the truck is setting in the sun and you look at it from the front,,,,, both sides look the same. The up side was I didn't have to worry about screwing up the paint job on the pillar. (You know,,,,, the old "Drop it in the dirt while the paint is still wet trick" or the "paint I used peels off after 6 months cause I didn't prep it right" problem. [undecided]<br> I was well pleased with the Auto Meter A-pillar in the way it fit. I removed my stock pillar instead of covering it with the AM pillar and used the "one screw at the top" method to hold it in place. Fits like a glove! ;D <br><br>
Re:Guage Pods
I did the same as Dennis, with the Propod. I have the agate interior, and the pod matches perfect. ;D Also did the one screw trick, but I used 2 instead. Saved the factory cover from cannabalism
Re:Guage Pods
Could some body explain exactly where to put the screw? I have had my pod in for about 4 months now and it still isnt secured very good. :-[
Re: Re:Guage Pods
Funny you should mention that. I took my Function-14 printout with me to a dealer close to work over my lunch hour. My '01 interior code from the print out is -AZ Agate. Crossing that in the Mopar touch-up paint book spits out:
p/n 82201399
Code: LAZ
Agate Interior
about $8 for a 5 oz. rattle can.
p/n 82201399
Code: LAZ
Agate Interior
Mechanos, LAZ and AZ ARE the same paint code. For some reason Chrysler sometimes puts another letter in their code. If you were to go to any paint supply store or body shop, they could look up either code and come up with the same color.
Thanks for the info on the paint codes....
1baddually
01-17-2006 02:53 PM
Fog U Later
08-21-2005 12:01 PM
