guage electronic sending unit
where does everybody put their sending units for electrical guages? i just got my guages and didn't know that they were goign to be that big.i was thinking of just zip-tying it to the rest of the rats nest under the dash. are they sensitive?
Re:guage electronic sending unit
not sure about "most people". I always recommend the tried and true mechanicals but people still buy the electrics...
I went electric on the fuel pressure for two reasons. One being most important to me, I dont want to run fuel in the cab in case of a leak and the isolators for mechanical were not proving reliable. The other is that after much research and finally talking to Rod at Wildcat the Dakota digital FP guage uses a VDO sendor that has been very reliable for his set ups. I ran a Isspro mechanical for a short while then switch to the Dakota electric and the readings were identical.
Westach here. Sending unit just went bonkers on the way home from Arkansas. Ordered another, $35 for the sending unit. >
Trans temp guages are electric. If they make a mechanical one its probably expensive. Pyrometers are mechanical. No sender. Just the guage and thermocoupler, but if you have the Isspro EV pyro then you also have the ampifier box to put under the dash.
Trooperthorn
02-02-2008 11:58 PM
mytrucksaslug
12-01-2007 01:08 PM
Scrambler250
04-29-2005 06:37 PM
