View Poll Results: What level GSK is Best ??
3K
12.50%
4K
87.50%
Voters: 8. You may not vote on this poll
Which GSK level is Best ?? 3K or 4K ??
Tough question!!
What is your truck going to be used for?
Do you drive on ice or through snow??
Reason I ask about snow is because I do and the 3 gsk made my throttle alot more sensitive. This can be a bit scarry on ice (my 94 went sideways at 70mph + more than once. I like you am intersted in others thoughts as it is time to order a gsk for my 96.
good luck
good luck
I bought the 4GSK for my truck. I figured the $100 price difference wasnt bad for the 12 valve springs. I figure that it cant hurt to replace the vlaves springs at 235K on the ticker. I plan to add the 3 GSK and then the little spring if I dont get the fueling I want. I have read several times of minor driving, starting, and surging problems with the 4 GSK. Also You cant buy the extra spring to make the 3K a 4K so it only made sence to me to get the big kit and save the extra spring till I am happy with the fueling.
I added the 4K
basically cause There were no 3Ks when i wanted one. Now surely i cannot rev to 4K safely just yet, (retainers and holder pending) BUT if i decided i want more fuel up in the higher RPMS to spool twins or somethin, I already have the Kit and dont have to worry about takin the assembly apart again. So far i can fuel hard to about 3800 but then it becomes with a 100 plate a race between the tach and pyro, and a hopeful prayer that no valves get dropped... Hence why i dont do it so often.. A 3K is safer and upgradable, BUT a 4K will fuel further into the powerband than a 3K... So its a matter of preference..
But in simple terms, Id rather have left over than keep wanting more....
Tx
Tx
Tx
Tx
1generationkid
05-10-2011 08:58 AM
VikingDiesel
08-03-2007 08:05 PM
MR HYDROSEED
03-09-2005 10:49 PM
Got Smoke?
10-26-2004 03:57 PM
