Gsk?
Old 08-15-2007 | 12:17 PM
DRam11's Avatar
Gsk?
Time to admit my ignorance. What is a GSK? I know it's something that can be a pain to install, requires care not to drop parts into the engine while installing, takes about two hours to install if nothing is dropped, has twelve springs, comes in 3K and 4K variations, and increases power. But what is it?
Thanks for alleviating my curiousity and ignorance.
DRam
Old 08-15-2007 | 12:21 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
GSK....Govenor Spring Kit...Helps to increase the RPM range from about 2600 to 3000RPM plus before de-fueling...Kit includes two springs.Not that bad to replace.
Old 08-15-2007 | 02:10 PM
ajoebob's Avatar
if you go with the 4k(4000rmp) or the 5k(5000rpm) you have to change the valve springs to HD(60psi) springs.
the 5k gsk is normaly only used in race trucks and takes a more engine work
Old 08-15-2007 | 03:02 PM
97DodgeRam's Avatar
One thing to add; w/o the GSK kit, the stock governor springs defuel around 2200 RPMs.
Old 08-15-2007 | 07:05 PM
DRam11's Avatar
Thanks. Very interesting. The information leads to other questions. Does moving the AFC forward affect the de-fueling point of the governor? Or does that affect another part of the fuel managment system? And, does installing a 3k GSK affect fuel mileage under normal driving? I ask because after moving my AFC forward the engine willingly revs to 3000 rpm when it used to reach only 2500 - 2600 rpm, and the mileage appears to have suffered somewhat when cruising down the road with no load on the truck.
Old 08-15-2007 | 09:01 PM
displacedtexan's Avatar
I can't comment on milage, as I owned my truck 5 days, and then did all the mods in my sig...
But the AFC is low boos fueling, off idle till about 6psi. It increases resposiveness, and smoke.
Old 08-16-2007 | 02:12 AM
wcbcruzer's Avatar
I wouldn't even think about a 5kgsk.
Old 08-16-2007 | 08:24 AM
Serious competition only. You would need bottom end work to run one...
Old 08-16-2007 | 07:13 PM
stirpicult's Avatar
ok, newbie question warning...
since this thread is up...this is my first diesel and first auto. do the GSK's change your shift points as well? mine truck shifts around 2000-2500 when i am on it right now. is this because it's defueling at 2200? so with the 3k, i will be shifting at 3000? or just have fuel until then and take care of my shift points on my own?
Old 08-16-2007 | 07:42 PM
It won't change your shift points. Mine did though
Old 08-16-2007 | 09:56 PM
stirpicult's Avatar
ok, so for us auto guys, how do we do that?
Old 08-16-2007 | 10:14 PM
IDK, have DTT or someone build you a VB to shift the way you want? I'm pretty ignorant on automatic transmissions.
siebertl
06-10-2007 03:29 PM
SHARPMACHINE
03-06-2007 09:45 AM
plow
08-09-2005 05:25 PM
MR HYDROSEED
03-09-2005 11:49 PM
Got Smoke?
10-26-2004 04:57 PM
Quick Reply: Gsk?
