Grinding my own fuel plate?? 12 V
I have read a few times that I could save money and grind my own fuel plate.... How does one go about that? Is there a post that describes this in full? The whole fuel plate and sliding it up and general pump stuff has me wondering... I have a 96 12V Auto trans and 105K on it. I am all about free power!
A broken pin from running with out a plate is just a myth.......a wives-tale to keep people frome removing them and giving p pumps a bad name. That came straight from the local pump shop......and he's been building pumps for a very long time. He took the plate out of my dads truck back in 97 and today the truck has 346k on it and never has had a problem.If people knew they could just remove the plates, there would'nt an aftermarket for them.
Whoaaa Logskidder! hahaha Just want to tweak it a bit for now. Nothing more then the stock trans can handle, which should seem like a rocket compared to stock. I am strating to gather stuff to sell on eBay to raise some funds for a converter, maybe a valve body upgrade. I've got the boost gauge, Shopping for the Pyro and trans temp. Have to cure that pesking heat exchanger leak... trans fluid everywhere! Anyone know if 24 valve and 12 heat exchanger will interchange? Same thing only different! Thanks for all the info folks! keep it coming!!
cLAYH
02-06-2004 11:59 AM
