Grill blanket inserts
Old 10-19-2004 | 08:20 AM
xp8103's Avatar
Thinking that the Lund units are going to fill the bill. No drilling or gluing or screwing necessary.
Old 10-19-2004 | 08:25 AM
Dr. Evil's Avatar
Originally posted by Homestead
I have run these for 2 winters now and they work great.
http://www.cloud-rider.com/
I have these as well - including the ones for the intercooler openings.
There are two versions - all season and winter. No drilling, or glueing or screwing here. They are mounted by clips and long screws that go through the clips.
Old 10-19-2004 | 08:54 AM
Copenhagenjunkie's Avatar
[i]Originally posted by F. Flack. The system comes with "self adhesive" snaps that didn't want to stay put. I replaced them with stainless snaps which I fastened to the grill with stainless steel screws.
Franklin [/B]
I have never had a problem with the snaps. I did make sure the grill was really clean(lotsa rubbing alcohol) and was nice and warm when I attached the glue on snaps. They fit is a little off with hood deflector though.
Old 10-19-2004 | 10:04 AM
CTD NUT's Avatar
I have had the Lund cold fronts for 4 winters and no problems. Don't worry about the intercooler getting warm. The charge air is so cold in the winter that you will not benefit from cooling it further. If the temperature is cold enough to use cold fronts, you won't need to cool the charge air much - unless your turbo is way too small for the amount of fuel you run!
Old 10-21-2004 | 06:55 PM
HOHN's Avatar
I just use cardboard cut to the shape of the grille and attach it with heavy zip ties to my billet grille. I painted them black so they don't look so cheesy.
I also run fanless most of the winter. Up to about 70°, I have no problems running fanless. Makes a big difference in warmup time and MPG.
Justin
Old 10-22-2004 | 09:31 AM
xp8103's Avatar
Fanless?
Old 10-22-2004 | 10:57 AM
Mechanos's Avatar
Originally posted by Shovelhead
larger pic.
mine looks like the ones in the bottom picture.
I ran the winter fronts on my '01 Sport last winter. When I took them off in the spring, I noticed a "line" of flatened fins on the A/C condenser coil. The flatened fins were caused by the hood latch mechanism being pushed back into the coil. I guess the extra drag placed on the grille by not allowing the air to pass through it was enough to force it back into the condenser.
I think this year, I'm not going to run them unless I install some short of protetive guard in front of the condenser.
Old 10-22-2004 | 10:59 AM
xp8103's Avatar
Ok... now THATS something I don't want to hear.
nvr-enuf
11-07-2007 03:09 PM
trik396
01-06-2007 02:56 PM
dhughe2
11-14-2006 10:31 PM
Wilson
04-01-2005 09:43 PM
Goldenbear
01-21-2004 07:49 PM
