Greater Fuel Capicity
Been looking to carry a little more fuel for long trips....
What have you done? Pictures are always great!!!!!
I've thought about both a bigger under bed tank and a in bed tank..... but open to all suggestions.....
I've got a Deezee brand toolbox/transfer tank. Holds 37 gallons. I've got it plumbed from the drain valve on bottom to a quarter-turn manual ball valve. I then put an electric valve underneath that, with the hose tied into the top of the fuel canister. Just a gravity feed system and will overfill if you just let it run, which is why I put the electric valve in. I've got it wired off the ignition with a toggle switch so I can turn it on and off and when the ignition is off, it shuts the valve. I'll try to get some pictures here in a bit for ya.
any luck with those pictures?
I've been looking into this a little more and I'd really like to know what all of you know/think about this before diving in......
I'm planning on adding a tank like this ( http://store.summitracing.com/partde...5&autoview=sku ) under the bed where the spare used to go. I plan on plumbing it from the bottom of the tank to a bung in the bottom of the OEM tank and the vent tube up to the top of the OEM tank. If I mount the tank roughly in the middle of the height of the OEM tank it should fill and drain along with the OEM tank. An extra 16 gallons will give me over 900 miles range. That's the theory, anyway....
titan tanks makes a replacement under bed tank. i thought about one just havent done it yet
http://www.titanfueltanks.com/
Transfer flow makes a under truck tank too. i just took a tank off a junk mitsu box truck and threw it in the back for an instant 50 extra gallons. its square in shape. left the "L" brackets on and just unbolted it from the frame. plumbed it so i can tank it on when every i want(quick disconnect.) used my old holly blue with a electric solenoid valve as a stop valve to prevent flow when not wanted. hardest part was finding a stupid gas cap for it
I just found an RDS tank that's 26 gallons for $205. It should fit under the bed. http://onlinemarine.com/rds_26_gallo...fuel_tank.html I'm still dreaming and thinking.... OldDodgeOwner: exactly how is that spare working out for ya.... (humor)....
Being a LB, you sure have more tank options than us SB guys. A bit of advice from a local welding shop...don't bolt the tank down so tight that it can't move with the flexing of the truck bed. Doing so causes stress cracks and leakage, so put some flat, rubber material under the mounting points to give it some relief. It works like a charm.
I found a 100gal (craigslist) LongBed "L" style saddle tank had it "shortened" to fit my SB. Fuel flows per D.O.T. regulation from aux tank to on/off ball valve gravity fed into factory tank. After the mod it's now 70gal leaving me w/total fuel capacity of about 95gal and travel range of about 1500mi w/out stopping. As if I could drive that long w/out stopping...LOL. Even after the mod it's way more than paid for itself when diesel was $4 and Mexico fuel was $2. Only bad part is that w/the tank and my tool box I have an even smaller bed.
