Got RCD lift kit
Got RCD lift kit
i just put a 6 '' rcd lift kit on my 99 dodge diesel . kit was not very eazy to install due to new longer lower arms had to drill like 6 holes for them grinded a lot then like 4 in the axle not as hard tho . 4 on front link mount . welded the track barket on due to the cummines no room for bolt .
but other than 2 long days of work i like the kit . only thang im not a fan of is the big block i think the block is like a 5 '' block . and came with a add a leaf . but the kit dident give it a true 6 '' prob more like a 3 or 4 in back .
one qustion has any one had any other probs i might need to check on or keep my eys on ect .
thanks nathan
thanks nathan
o ok i got ya when yaw git it back on let me know
o the bolt on the track bar i had the hole and could have put in but would had to lift motro up but even after that the clearence between the oil pan and bolt would have been hardly nothin might want to look @ that might hit your oil pan . it wouild on mine
Most lift kits do not raise the truck evenly. Their advertised height is the amount of lift the front gets. The back is usually enough lift to make it level with the front, typically 2-3" less.
Dale M
03-05-2011 03:40 PM
flynhigh205
38
11-18-2007 12:14 AM
bhoff1175
06-07-2006 10:19 PM
