Got my new steering box brace!!
Got a new steering box brace from Eric at Vulcan.
I was looking for one of the usual manufacturers and low and behold, Vulcan is building theses things now. Now if I can just get the time to get it mounted!
So now we have a local source for these items!!
Dave
Dave
Here's a couple pics guys. Sorry for the delay, I actually forgot to post 'em up until someone reminded me.
Contents of box.
I pulled the pitman arm nut off.
And dropped the sway bar out of the way.
I put a small bit of thread locker on the steering shaft as a bit of extra insurance.
And torqued the nut to spec.
I put the stabizer up loosely under the sway bar bolts. Again, a small bit of thread locker was used.
And the bearing goes in.
I used a little red thread locker on the bearing set screws.
Everything was tightened up and shecked for binding.
And I was finally done!
I immediately noticed an improvement in response time of steering input. However, I now notice just how bad my track bar is! So, that's next on the "to do" list.
I am very happy with the quality of the powder coat and the color as well. Eric did say he can do other colors as well, but they would require a bit more time.
Definitely one of the best things I have bought for my truck!!
Dave
Contents of box.
Dave
Yeah, night and day!
Still have that pesky track bar to do, but I think I am gonna build my own braket and go with a 3rd gen bar. I'll just cut and thread it at work.
Dave
Dave
From: Newman Lake, WA (But my home is deep in the heart of Texas!)
Good write up and photos
I see your '02 truck has a 2 piece tie rod where the pass side piece goes to the steering box
My '99 has a straight across one piece tie rod (except for the toe in adjuster), and steering box rod "ties" into the tie rod. My Tie rod looks bigger(larger diameter) than yours too and my steering stablizer shock has a clamp/ubolt bracket to the tie rod, I have the 88,000 gvw with factory heavy load double springs rear and sway bar in the rear also. Maybe thats why tie rod is beefyer too...? Anyone else have the one piece straight across tie rod like mine?
My '99 has a straight across one piece tie rod (except for the toe in adjuster), and steering box rod "ties" into the tie rod. My Tie rod looks bigger(larger diameter) than yours too. I have the 88,000 gvw with factory heavy load double springs rear and sway bar in the rear also. Maybe thats why tie rod is beefyer too...? Anyone else have the one piece straight across tie rod like mine?
When my steering parts need replacement, I am going to go with your setup.
Dave
