Got my Edge Juice today
I seen where the edge has a fuel pressure sensor that plugs into the port of the VP. My question is, I looked at my buddies setup and he has a FASS system where his main fuel line is plugged into that port. He does not have an edge juice. When i get my fass that is where i was going to plug in the main fuel line. Will I still be able to use that same port on the VP for the fass now that the edge's fuel pressure sensor is there? Even when i get the fass I want the fuel PSI to show on the monitor. I thought I had it all figured out now they threw me a curve ball
The fass system will come with a flared fitting with an o-ring to screw into the supply port of the IP and a 90 degree fitting for the end of your supply line. You can get some fittings from your local hardware store and make up t fitting to put in the FASS supply line to your IP to screw your fuel pressure sender into. I'm putting gauges on my truck this weekend and thats what I did. I got a 3/8" t fitting, a couple 3/8" barbed fittings with 3/8" pipe thread on the opposite ends of them, a couple hose clamps, and 3/8"x1/8" bushing for my sending unit to go into. When I installed my FASS system, i removed the factory fuel filter housing and lift pump, but left the lift pump bracket on, so I think I'm gonna zip tie the line with the t fitting in it fast to that bracket so its secured real nice.
MrSuzuki
08-25-2009 07:22 AM
razor6
22
01-20-2006 03:43 PM
djcheez
10-15-2005 04:13 PM
RamWheelsBy4
23
02-17-2005 02:15 AM
Big Bob
12-24-2004 04:10 PM
