Good solid 350 HP/??? TQ injector and turbo combo???
Old 01-30-2007, 11:16 PM
TorqueJunkie's Avatar
I am looking to make a good solid daily drivable 350 HP with what I got and adding some sticks and maybe a turbo. I tow 5-7K with the truck on a regular basis and drive the truck every day, so I don't want something that will take a small shot of nitrous to get spool'n but something that will work well through out the whole power band without some crazy pyro numbers either. I know I could do a whole lot more by stepping up to a comp box or a SMARTY and that will come with time, but for now I am going to stick with the EZ. I know I am pretty much wanting my cake and eat it too, but I know you guys are the combo masters so help a brotha out.
Thanks
Jeremy
Old 01-31-2007, 06:07 AM
Adam3291's Avatar
I'm not sure but I think a set of RV275 injectors will get you pretty close to your goal with the Edge EZ you have.
Old 01-31-2007, 06:18 AM
JD730's Avatar
F1 Mach 1.6's, HRVP, and a Smarty go me just over 360hp and 860 ft-lbs. Stock turbo with an adjustable boost elbow.
Old 01-31-2007, 08:33 AM
RustyJC's Avatar
See my signature. I have to watch my EGTs when towing my 16K 5th wheel (1450 degF is possible), but some more modern sticks around the same size as the DD2s (like Don M's 1.6s) could give you comparable power/torque with less smoke and cooler EGTs. For a towing rig, I'm at about my limit for the stock HX35W-12.
Rusty
Old 01-31-2007, 09:46 AM
SuperDave4x4's Avatar
A 35/40 hybird turbo would be perfect with your EZ and some mild injectors.
Old 01-31-2007, 06:52 PM
Tate's Avatar
Smarty, HRVP and Jammer2's got me 376 hp. I've never had to tow anything, so no idea on how it cools. I'm sure it would be toasty, considering I can get up to 1300-1400 in a good 4th gear run. Get some F1 injectors, should get more power and cooler EGTs than I have.
Old 01-31-2007, 07:03 PM
BigBlue's Avatar
An edge comp, rv 275 combo is pretty much guaranteed and proven 350hp combination. With that setup and a turbo I dynoed 373hp and could knock down 20mpg with ease. I miss that combination.
Old 01-31-2007, 09:35 PM
Thanks guys! I was thinking something along the lines of a set of Jammer 3's or Mach 1.6s with a PDR hybrid 35/40. What do you think about that? Eventualy I will sell the EZ and get a Smarty, but that won't be for a while.
Old 01-31-2007, 10:00 PM
SSweeney's Avatar
I will be getting a ps62/12, mach 1.6 with ez. I should be around 360hp with good spool and room to go up a little later with a TST pm3. From what I have learned on this site, it should be an awesome tow machine especially after getting a dtt tranny upgrade.
Old 01-31-2007, 10:15 PM
whazzup's Avatar
Be aware that the 62 combo with a auto, altitude, hi gears and a little larger tires was no good for towing but lots of fun empty.
Old 02-01-2007, 01:45 PM
SSweeney's Avatar
I quess I fiqured the Mach 1.6s and ez would get that 62 spooling good under load. Specially with a 12cm wastegate. Maybe I was wrong.
Old 02-01-2007, 04:37 PM
BigBlue's Avatar
I know a smarty and 155hp injectors will spool a 62/12 with incredible ease and will only hit about 1100-1200*.
Old 02-01-2007, 04:41 PM
Diesel-Dan's Avatar
Mach 2's, Smarty, and a 62/14 (Or 12) manual or 62/12 auto.......would be a strong running truck.....and i currently have NO EGT issues with just the 2's. My clutch just cant hold any more.....
Old 02-01-2007, 06:11 PM
Jetpilot's Avatar
The 12v is a little different animal than a 24v. Also altitude plays a big role in spoolup......
As for the original question going with a 62mm turbo, and Mach 2's will get you the 350 RWHP range.
Doug
Old 02-01-2007, 06:18 PM
whazzup's Avatar
What elevation are you at? 1000'?
My 62 worked very well as long as I did not go over 3500' elevation, once over that all bets were off.
I live at 6000' elevation and any direction I choose it just gets higher, I tried to tow my 7500# TT twice with the 62, after the second time I could not get it off fast enough.
When running empty the 62 was a blast to drive, a little bit more lag but not bad once the pump was tweaked some, at 115 MPH I was starting to hit 1300 on the pyro.
This is my experience only I am sure others will have something different to say.
Quick Reply: Good solid 350 HP/??? TQ injector and turbo combo???
