Gonna get my Hx-40, Step 4 Bully, and AfE Megacannon!!!!!
Old 02-27-2003 | 01:45 PM
Cumminsdieselboy's Avatar
Muted User
Do you think we will be able to beat another Ford with a diode, Injectors Box and Propane?<br><br>We also have a PE comp.
Old 02-27-2003 | 01:51 PM
PourinDiesel's Avatar
Re:Gonna get my Hx-40, Step 4 Bully, and AfE Megacannon!!!!!
What Clutch or Auto Trans Mods are you running??<br>If your going to run that much power with an Auto, I suggest the ATS Triplelok torque converter and transmission. www.ATSdiesel.com<br><br>Manual Clutch, either Mitchell or South Bend Clutch.<br><br>You will probably have close to 500rwhp and about 1000ft lbs (depending on what dyno you run on)<br><br>Good luck! and Congratulations! I hope you smoke that Ford (which you will do)<br><br>--Justin<br>
Old 02-27-2003 | 02:05 PM
Jetpilot's Avatar
I am betting more around 425-450 on the HP. Also I recommend a DTT transmission upgrade. Good luck and have fun.<br><br>Oh yea, if you are going to be racing you should join the DHRA at: www.dhraonline.com<br><br>Doug
Old 02-27-2003 | 04:09 PM
OverFueled's Avatar
I have RACED (1) Ford with a chip and Propane. From the look on his face at the start he thought for sure that he was going to go past me. In the end when I let him catch up to me he gave me the &quot;thums up&quot;. OverFueled
Old 02-27-2003 | 04:33 PM
Muted User
Gonna get a Pheonix Remanufactured and beefedup trans with billet tc and vb.but i heard from the guy that sold the stuff were gonna have 475 and 900 with out step 4 injectors. The guy was doug at ADT or smokindiesel.com.
Old 02-27-2003 | 04:36 PM
J.R. Adkins's Avatar
Hey Jetpilot (Doug) your links in your sig dont work.
Old 03-03-2003 | 04:02 PM
hellotbone's Avatar
Why a megacannon and not a scotty 2?
Old 03-06-2003 | 10:45 AM
danlit's Avatar
? 475&amp;900 with what done?
Old 03-06-2003 | 06:15 PM
Muted User
why megacannon? i think it looks better than scotty 2. 475/900 with just hx-40 turbo.
Old 03-06-2003 | 06:40 PM
Bob Wagner's Avatar
I just posted a classified ad for a set of bullydog 4's <br><br>check it out
Old 03-06-2003 | 07:04 PM
Cmonroe's Avatar
I'm with Jetpilot on this one. With those mods you will be around 440hp. However I would recommend an ATS tranny. 8)
Old 03-06-2003 | 09:15 PM
KatDiesel's Avatar
You'll be 475hp easy, as long as your fuel system keeps up. Wether you can get it to the ground is another matter. (Transmission)
As far as the Ford, it depends on how well you can drive and the weight differences.......if its a 1 ton dually like yours, then yes you will beat him. Depends on the weight difference.
Old 03-06-2003 | 09:53 PM
Racer57's Avatar
No offense, but don't think you can get over 500rwhp with the HX40. Maybe close with a PDR 50/55. I know quite a few with similiar mods and none over 500hp. I think that you would have to stack an EZ or VA with a TST3 to achieve that. Just my opinion.
Old 03-06-2003 | 10:38 PM
Jetpilot's Avatar
I saw a guy make 507 RWHP with Bully Dog 6's, Edge Comp, and a PDR HX-40.<br><br>Doug
Old 03-06-2003 | 10:47 PM
danlit's Avatar
