Goerend Trans
Goerend Trans
How hot does your Goerend Trans get? If im sitting at a light for a little bit the trans temp gauge will start to climb and get to 200 at that point ill shift to N and let it sit ive never had it go past 200 degrees. any one else have this happening?
200 is about normal temp for sitting still. When you take off i bet it jumps right back down since the torque converter is circulating the fluid again.
Where is your sender for your gauge at?
I just got off the phone with Dave @ Goerend and asked him about gauge placement. Your seeing the hottest point in the transmission. I wouldn't worry about it unless it got over 230-240 degrees. If you get to 250 is when you will start hurting your transmission.
My temps have been very low since the new trans but I will finally tow something this weekend, my temps have been no more than 185* vs 210* with my old trans. Temps taken hot line.
Just curious.
Sense you seem to be in the know I have a 15 blade left cut I believe. He recommended this as it's used to tow in the Rockies, same torque multiplier 15 blade but cut at the ends vs his sled puller, 1/4 strip that is not cut. Does this run hotter or cooler?
Just curious.
Just curious.
Brett
I didn't catch a thing with all the cut back cut and cooler so I hope mine is cooler in traffic??? He showed me a stock 17 blade and then 17 blade his way and then only 2 15 blade torque multipliers (as he calls them) So a left cut and a no cut as your calling them. What the heck is a left cut back vs a left cut. If I were to have a rectangle as a blade for my converter he cut out a triangle on the bottom side or rear of the blade, says is makes more pressure with the longer blade but quicker spool (pressure?) from the cut?
BossHogg
16
03-14-2008 03:14 AM
ataboy9026
25
11-22-2007 08:34 PM
Sixpack73
13
06-09-2007 02:27 PM
Cowhand
01-12-2004 09:54 PM
