glycol tire balancing
Old 02-27-2005 | 02:49 PM
Dufrain's Avatar
http://www.innovativebalancing.com/news.htm
Old 02-27-2005 | 03:38 PM
infidel's Avatar
Originally posted by KATOOM
After reading up in that site, am I right to understand that you are putting a bunch of little ***** in your tire? How could they possibly stay in place while stopped? Dont they make noise? What happens when you need to fix a flat or even have new tires put on? Sounds cool but I just dont see how it could work well. Plus I would think they would eventually bang them selves up and be no good.
The beads are very small, like the size of a pin point, pictures on the site are enlargements. The company that makes the beads doesn't say it but upon removing a tire it's very obvious that static electricity acts very strongly on the beads keeping them in place. A hard bump will dislodge them though. Besides the ceramic material being very hard perhaps the small size of the beads keeps them from banging each other up into dust.
I had a nail hole patched from the inside and didn't lose any beads but I warned the tire guy they were in there. I've never done it but I'll bet after a flat repair it's probably a good idea to have your tires rebalanced, no need to with beads.
All I know is they work excellent for me.
Asked the manager at the local tire shop about anti-freeze, he said it works ok but you must use premix or 50% water because anti-freeze alone will gel up in the cold. He also said to use the non-toxic or RV anti-freeze type due to a leak of toxic material in a blowout that could get you in trouble. I can see this happening considering a friend of mine got a $500 toxic cleanup bill after his radiator was punctured in a wreck and leaked anti-freeze at the accident site. He said a fire truck came and vacuumed it up.
Old 02-27-2005 | 08:38 PM
Eskimo's Avatar
I ran Anti-freeze and water inside my 35" Boggers for years... the insides of the tires looked GREAT when the beads were broken... AF/water mix was in there for probably 3-4 years.
Old 02-28-2005 | 11:33 AM
Nuttymopar's Avatar
I agree with Infidel. I have had not problems with my ceramic beads. Have lasted about 10,000 miles and tires are wearing very well. They even straightened out my cupping on the front tires. I rotate tires about every 7000 miles now instead of the typical 3000 for my 1st gen.
Old 02-28-2005 | 12:15 PM
Mcmopar's Avatar
Did he say "FIX A FLAT"????? Your kidding right??
Old 02-28-2005 | 12:29 PM
Dufrain's Avatar
Anyone tried this stuff,its supposed to balance out to.
http://www.ride-on.com/index.html
Old 02-28-2005 | 12:34 PM
infidel's Avatar
This brand of fix a flat says it can be used for balancing, only problem is it costs over $100 to do one of our trucks. http://www.ride-on.com/installationinstructions.htm
Most fix a flat products will eventually turn soild and throw your tires way out of balance, that's why it's a temporary flat fix so that during the real tire repair the fix a flat can be removed.
Most fix a flat products say not to go over 45 mph.
eastmentCTD600
09-07-2006 10:08 PM
Jmac
15
04-22-2005 03:22 PM
billmac
118
02-07-2005 07:20 PM
CaughtinmyGrill
08-28-2004 04:50 PM
apache
12-29-2003 11:20 PM
