Glacier fuel system??? any good??
I was wondering if anyone out there knows anything about the glacier fuel pump?? I am in a toss up between a glacier or a Fass system. I am going to be running a edge juice with attitude, stage 2 injectors, and intake like 53 ****** whistler system, maybe more later. What pressures will this pump allow me to run?? and how reliable is it. I want something to hold pressure when I am smoking buy some ricer with my stage 5 or 6 turned on and not be running a mear 3-4 psi which is recipe for disaster. I cant even turn on my juice power yet with a new lift pump and new vp44 psi drops to 3 and 4 psi at WOT preasures are 10-11 and a rare 12 at times when at idle. Need help!!! I want to run 10 or 12 at WOT when the juice is turned up.
theonyz
theonyz
I have one, and I never see less than 14lbs, ever!! The only problem I had was on a -15 degree day the bypass valve hung up and I had 0lbs presure. I was still at home so I took a hair dryer and warmed it up and it has been fine ever since.
Welcome to DTR Z !!! time to fill out your sig line now....
The air intake made by 53 ****** is on a 3rd Gen truck, but here's the link for any of you interested.
https://www.dieseltruckresource.com/...ghlight=******
jwb600
14
01-28-2008 04:26 AM
OT-OF-Here
09-27-2006 11:21 AM
Igor
06-02-2006 08:49 PM
