Getting ready for modding my 2002 HO 6 speed
Ive done some reading and had a few phone calls, so
First fuel system upgrades and gauges. Check!
Getting ready for turbo and injectors On the fence!
Got my methanol injection kit pieced together, all my cars have meth injection
OK, so for injectors, swapping in some 125 HP nozzles is that good for fuel mileage and not too aggressive with HP? Not going crazy with large injectors,... Will it make the same power with nozzles vs entire injector?
Smarty is going on the truck, it should make an additional 125 hp right?
Turbo.. Single... hx 40 ???? ebay????
I will need a better clutch, will a puck clutch work fine? I dont plan to drag race the truck, nor do i plan to do 3rd gear launches with it. I just drive it and want SMOKE and power. It feels neutered stock right now.
Just asking questions if someone has done it before id like to hear from you, id get a con ofe clutch but dang those are expensive.
what I did to my truck ..01 makes it a strong quick puller and gets great MPGs I dont drag race I tow heavy loads and I can set the CC at 60 and hold it at 7% grade and thats pulling a 16900 lbs trailer
Imo if your putting a smarty in the mix, buy a good clutch they are $ for a reason. when I had just 90 nozzles with smarty I could still slip my OFE. went to a FE when I put in mach 4's (150) and could slip the FE. now I'm happy with the double disk, so yes I have spent alot in clutch's (wish someone would have told me to save and buy one clutch the first time). with the smarty alone your HO will drive and respond night and day diff, injectors and smarty with a HO is a nice combo. my nozzles were okay. but the mach's I put in were cleaner, smoother and i did see better mpg if I kept my foot out of it. there are other injectors out there that are good also. you are on the right track with the gauges and fuel pump upgrade first. good luck
I've been running a Smarty and Mach 4s for about 4 years now. It's a great streetable performance rig with the stock turbo.
The Con FE has performed admirably with this setup. It's a little grabby initially, but smooths out over time. It's great with 2nd gear starts.
I recently thought I got my FE to slip, but haven't been able to reproduce it.
I have upgraded fuel plumbing, but stock lift pump and filtration. Never run out of fuel with M4s. Saved a lot of $$ over most of the aftermarket setups by only fixing what's wrong with the stock parts.
Best part about the M4s is that the smoke is pretty easy to control with the 6 speed. I don't mind a little smoke, but I tolerate it, not seek it. If I could make it super clean and make 150hp more, I'd choose that instead.
For a fuel pressure guage, I used a cheap liquid-filled gauge from Jeg's for $25 or so. Works great, no senders to die. Fits perfectly in the tweeter spot on my pillar, so the other 3 guage spots are available.
If you upgrade your clutch, don't forget to beef up the pilot bearing in the flywheel. Factory unit is not up to massive torque, and when it gets loose, the shaft play will take out the front bearings in your trans.
I used the Torque King from Quad4x4-- http://quad4x4.com/
JH
JH
Hey thanks for the post, I think I am doomed on this pump.
Put this pump on from cummins and it was low on power, then backfiring thru intake,,,,,, sent it back and they said computer was bad on pump.
Broke it in for 500 miles put box back on and it's like it has timing but not fueling. I want my old vp 44 back it would fill a minivan full of smoke this one will not fill a beer can
he was commenting not what caused the smoke. more than a dirty filter would do this. but in todays world. everyone trying to get power, cleaner, quicker, if your just dumping black smoke your doing nothing. not good for other people driving. not good for a image for those who have diesels and care to not do this to other drivers etc. but there are far more diesel "Nerds" on here that have been there done that and found the correct combo for these trucks to get power without smoke, cleaner burn, better egt's etc. learn from the ones that know what they know and what they tell you. otherwise IMO many people are just wasting money, not getting any more better MPG performance. so like was said just cut the intercooler line and be done. you still would get the bad spool and smoke and high EGT
I'm just fet up with this pump, it's brand new and been repaired once already with new computer board... Broke it in for 500 miles, put horse power box on it yesterday, truck only makes 26 psi of boost and zero smoke.
It's like this new pump is down 100 horse compared to stock pump.
The old pump would make tons of low end torque. Lots of black smoke at any rpm and used to make 38 psi.
Wonder if how this pump was set up at pump place that it's not setup like my stock pump was...
Arrrrg I'm frustrated
Backfiring through intake seems to point to installation error. Timing is most likely off.
JMO
It was running perfect once again zero codes and no issue till I got on the highway. This sucks. I'm thinking of mechanical p7100 if this one fails again
Might want to try a different rebuilder.
Not questioning your mechanical skills-- even tech here are the mother ship sometime make a mistake (and they work on the SAME engines all the time).
Had a rocker shaft installed backwards earlier this year. Valvetrain carnage was impressive.
Yeah it's just my luck too, I really don't think there could be anything on my end causing the vp44 card to fail. Last time I was driving down the road and the truck was running great then all of a sudden it started popping and farting out the intake and it all started when I set the cruise
This time it just failed, when I shifted to 5th gear getting on the highway..
I left work early and pulled it this evening, I asked for a different pump but was denied.... New apps and new inline pump...
1500.00 for a p7100. I'm thinking about converting it over
ROCKNRAM
12-03-2007 02:19 PM
Artsi_L
12-26-2005 03:52 PM
Barrett_Fodder
10-07-2004 12:12 PM
gasgas19
06-13-2003 12:15 PM
