Getting Mad!
Getting Mad!
![Mad!](https://www.dieseltruckresource.com/forums/images/smilies/new1/madani.gif)
do they recomend running the stage 5 jammers for street use? I thought they were for competition pulling. I maybe wrong I have a 12 valve but the stage 5 jammers seems abit overboard combined with the juice with attitude just to much fuel and not enough turbo. Remove the jammers and try the stock sticks I bet you'll be all smiles. but maybe somebody with a similiar setup that has had this problam will chime in.
The Guru
How much boost you pulling at wot? Those are pretty big sticks for a stock turbo. You could also try running them with no box and see what kinda of egt's you pull.
wait a sec ,you mean to tell me that you are running a tapped fuel box and 150hp sticks with a 9cm hy and you dont know why your egts are out of control?Hmmmmmm,need turbo?
![Dummy!](https://www.dieseltruckresource.com/forums/images/smilies/new1/smashfreakB.gif)
Registered
Originally Posted by kelownadiesel
wait a sec ,you mean to tell me that you are running a tapped fuel box and 150hp sticks with a 9cm hy and you dont know why your egts are out of control?Hmmmmmm,need turbo? ![Dummy!](https://www.dieseltruckresource.com/forums/images/smilies/new1/smashfreakB.gif)
00 should be the 12cm housing, but still
Too much injector
Back it down to Stage 2 or 3 injectors
Or leave the box off or on Level One
Or change to something along the lines of a HTB2 62/14 or PS62 14 turbo. Or twins
Too much injector
![Smilie](https://www.dieseltruckresource.com/forums/images/smilies/smile.gif)
As mentioned above an upgraded turbo is the only way to control the egt's with your mods. There are lots of good options that will really cool down your temps plus add the air to burn the fuel you are delivering.
Doug Smith
Doug Smith
Doug Smith
Doug Smith
Hey doug,you guys ever get those custom 12mm studs made?Do you have to machine the block still?
Doug Smith
M Penwald
14
03-26-2011 08:41 PM
