gettin on the dyno....
#62
BD, let put it this way. I've got a stock HO pump, TST comp, Smarty, Twins, and injectors that made 230 RWHP in an SO truck, but only 180 RWHP in mine and I am barley over 500. The numbers I put up on the list that is floating around here were in 5th gear (1:1). The last run we did in 6th we could get a good reading and there were 20 other pickups waiting so I had to get off. But going by my other numbers I'm just a little over 500 RWHP. Something else to remeber is just because you've got 220 HP injectors and a 180 HP box doesnt mean your going to see 400 HP. In reality it will be more like 325-350.
#65
i think the 325 - 350 is about right. That will put me at 505-530. which i believe is close
#69
#70
id put you around 480ish with the twins
i did 420 on an oversized single, 150sticks, and comp box with stock HO pump
#71
#73
Twins are nice... Truck loves those cool temperatures... My favorite is pulling 12k up a grade accelerating and not even having to worry about the temp gauge... (TST turned bout 2 or 3, Smarty on 5ish).
#75
I'm scared !! I prolly will this weekend not much though... When I'm fueling hard I'm seeing around 51/52psi now... What do you suggest I should run on the dyno?? Will it provide enough load fo rme to full boost anyways?? Have to remember I'm new to this
