gettin on the dyno....
9 settings on the tst x 10 settings on the smarty x meth on or off = 180 combos- get a testing
See if he will rent the dyno by the hour. Normally shops have a per run rate (high) and an hourly rate (lower), the hourly rate is normally between $75-$125 an hour. If you can get the hourly rate you could do the pump swap and everything that day to see the results......
Doug
Doug
Doug
Doug
So if all goes as planned, i may have my truck back on the road by midnight. i think they may be closed. LOL
ill see if i can buy an hour like you said. use 30 minutes now and 30 minutes later. he dont like the dodge boys...
you have 220hp injectors over my 150's and the H2O/meth, but i have the HRVP44...and i did 500/1021
im gonna guess you will be over that, but not by much, 62mm will be nearly maxed, as well as the HO pump is really straining for you.im gonna say 530/1100 max
But it may make differences between max and lesser combos smaller... no?
Wouldn't there be less heat soak to start small? Also, with hood up and a fan in front of the truck, is heat soak that big a factor? I mean any more so than driving down the road?... or multi passes at the strip? Never really considered this... but it's worth thinking about.
If heat soak is an important consideration, than doesn't it make any back to back dyno runs (with different set ups) inaccurate? On the other hand, guys who do three runs at same settings don't necessarily see best HP/TQ on first run.... do they?? I haven't, based on my past print outs.
No input for you, 'Blackdiesel' ....just asking questions.
RJ
