Geno's painless fuse block
Old 01-24-2003 | 09:45 PM
MARKY MARK's Avatar
Anybody using Geno's Painless 7-cirkit boss fuse block? I ordered the 4 ignition hot/3 constant. How does it install? How do you like it? I am going to use it for fog lights, driving lights & backup lights. Can I use it for guages?
Old 01-25-2003 | 12:33 AM
Bart Timothy's Avatar
Re:Geno's painless fuse block
I have the weather-resistant model mounted on the firewall next to the clutch hydralics tank. It's overkill for guages but can be used if you replace the standard 20 amp fuse. I think it would be a better unit if it used a terminal block instaed of pigtails.
Old 01-25-2003 | 12:40 PM
JGK's Avatar
JGK
I have the interior one behind the dash. Works great. But I've just about used up all the connections! And yes, you can use it as a power source for guages, if needed.
Old 01-25-2003 | 12:45 PM
Shovelhead's Avatar
Administrator / Scooter Bum
I've installed the weatherproof panel and it's 8).
Mounted mine on the firewall next to the brake booster.
I like the pigtails on this one 'cuz you can solder, and weatherproof the connections, otherwise being exposed to the elements, push on connectors can get corroded.
Ed
Old 01-25-2003 | 07:36 PM
turbo thom's Avatar
I've had the painless connector for bout 4 years. I installed it on the fender well under the battery. Well I had a battery explode and the acid ate the the main fuse up. I have another one and it will power eveything you need. I have my dash gauges, back up lights, radio power, cb....... yep, Just anything you need. And I still got 2 lines left.<br><br> I love it. <br><br>..Preston..
Old 01-25-2003 | 10:47 PM
TPilaske's Avatar
I have the 4+3... Love it! ;D I have one wire left. <br><br>I removed the knee bolster and mounted it in there... there is a great spot right on the right side of the steering column... and all the piggy tails are easily accessible. ;D<br><br><br>Tony
Old 01-19-2007 | 09:47 AM
DodgeCowboy's Avatar
DTR's Cow Boss
Here is a blast from the past I am wanting to get the Geno's kit also but am unclear as to how the connections for the accessories are made? do you have to un bolt the block from the mounting place or is there a spot were the wires push in or what???
bigragu
10-08-2014 01:05 PM
GOT BOOST?
08-21-2008 07:59 AM
Cowboy45
09-07-2006 12:44 AM
hotdram
01-10-2005 04:10 PM
Gypsyman
06-15-2004 01:15 PM
