general gauge install ? for stock truck
Old 01-10-2008 | 01:01 PM
RAFTEN's Avatar
Sort of related, if you install a electric WesTach fuel pressure gauge, be aware that the hose they use is not good for biodiesel. They get soft and sticky, then they burst.
Old 01-10-2008 | 02:51 PM
Busboy's Avatar
Originally Posted by jay_naz
Well, I've installed and tested my fuel pressure gauge and boost portion of my boost/EGT gauge. Don't have the lights connected yet. I'm not sure that I have an ashtray light on my 99. I don't see any light. Where should it be? Also here are my Fuel pressure readings: idle 11-12 psi, cruising 8-9 psi, WOT 6-7 psi. What are the thoughts? OK or lift pump getting weak. I have 87K on my stock truck.
If you remove the ashtray holder the light is in the silver metal clip on the top. The bulb holder just pulls out. It's very easy.
ado2b1
07-06-2007 10:27 PM
engcogod
17
02-03-2005 08:49 PM
lucey
01-27-2004 05:33 PM
crossy
11-08-2002 08:19 PM
Quick Reply: general gauge install ? for stock truck
