Gear vendors OD not working...help!!!!!
Old 09-13-2005 | 06:52 PM
CTD_Neil's Avatar
I have the GV overdrive unit on my truck. I mostly used it for an extra overdrive on the freeway. That was until it quit working!!!!! Now when I engage it it holds for about 2 seconds then....WHAM it unlocks. I'm cussing it right now. Has anybody had this problem with their OD unit?
Old 09-13-2005 | 07:33 PM
Fat Framer's Avatar
check the fluid level. The overdrive depends on fluid presure to keep it engaged. If fluid is good, when is the last time it was changed. There is also 2 filters that need to be cleaned. The main one in the bottom of the pan and a small insert filter that is under one of the 3 screw in plugs inside the unit accesed by removing the pan. There is also a check valve in the smaller of the screw in plugs that may have to be cleaned(it consists of a small ball bearing and pressure spring). go to this website and contact them direct if none of the above work: http://www.gearvendors.com/
Old 09-13-2005 | 10:10 PM
600 Megawatts's Avatar
Muted User
Yep, same thing I said on the other post.... sounds like fluid is low....
Old 09-13-2005 | 10:17 PM
storx's Avatar
beleave it or not someone had a problem with there GV overdrive and it was the batteries a while back......
Old 09-13-2005 | 11:36 PM
CTD_Neil's Avatar
Batteries? Where are they located?
Old 09-13-2005 | 11:51 PM
BigBlue's Avatar
Truck batteries. They are located under the hood, right behind the headlamps, on both sides of the trucks. They both have one red wire and one black wire going to them.
Old 09-14-2005 | 12:07 AM
CTD_Neil's Avatar
Funny, He made it sound like their was a battery for the GV. My truck batteries are Optima red tops and they are in good shape.
Old 09-14-2005 | 11:19 AM
storx's Avatar
that what you say but your GV overdrive may be saying elsewise........
Old 09-14-2005 | 11:43 AM
CTD_Neil's Avatar
I called Jeff at GV and told him what is going on. I tested it this morning and payed attention to the light on the switch panel. I am going to call him back today and see what he says.
Old 12-22-2005 | 12:44 AM
mhuppertz's Avatar
He Neil, what turned out to be the problem with your OD unit? Mine doesn't go into OD at all, but when I engage it I loose engine breaking. If I turn it off (WHAM) the engine breaking is back!
Old 12-22-2005 | 03:26 PM
CTD_Neil's Avatar
Well I still haven't looked at the speed sensor yet. I called GV and the tech wanted me to verify i was getting a A/C signal from the sensor while the wheels are turning. Haven't had time....stay tuned. Actually it worked for about 1 minute couple weeks ago. so I know it's a loose connection, flaky signal, or bad wire most likely. It sure is nice to have that extra gear on the freeway with 4.10's
Old 12-23-2005 | 12:04 AM
Jim O's Avatar
[QUOTE=mhuppertz]He Neil, what turned out to be the problem with your OD unit? Mine doesn't go into OD at all, but when I engage it I loose engine breaking. If I turn it off (WHAM) the engine breaking is back![/QUOTE
Installed mine this week and it is working great. If I had a problem I would call 1-800-999-9555 and ask for the technical dept. I found them very helpful.
Jim O
Old 12-23-2005 | 12:17 AM
cummnz4x4pwr's Avatar
Exclamation
Ill tell you what Neil just send it to me its not worth the trouble
Old 12-23-2005 | 08:47 AM
mhuppertz's Avatar
I called GV, they said that my OD clutch is burned up
They want $750 to rebuild it, but I think I will just get the clutch and do it myself. The other clutch is fine....
Old 12-25-2005 | 02:24 PM
napa 600's Avatar
well in my case it was exactly what you described; a goofy a/c signal. the fluid was a little low as well. just my .02
