gauges and a-piller
Old 03-05-2005 | 10:57 PM
gasitman's Avatar
gauges and a-piller
I got a autometer a-piller from a another board member, in the instuctions it says to use this cover ontop of the existing a-piller, is this true? What are the best autometer gauges to use? I would like the white faced, but I was wondering, do they make a white faced gauge cover the the stock speedo, tach and other main gauges? If so, where can I get them?
By the way, I have a 2002 ctd.
Old 03-05-2005 | 11:08 PM
got...DIESEL?'s Avatar
there are white faces on ebay all the time +/- $35.00. jusat make sure they are for the diesel, as there are also LOTS of gasser gauges too. There is also a heater control panel overlay to match. And yes, the a-pillars fit over the stock pillar cover. Some use plastic rivets (which suck) and others have you use small screws.
FYI, needle replacement accuracy after the white face install is only as good as how well you mark them before the teardown. Pull the speedo peg BEFORE you pull the needle, as it is preloaded, and will settle in a different place. Pull the rest of the needles after you baseline mark them with the ignition ON. And replace them with the ignition ON and all other engine conditions the same!!
Chris
Old 03-05-2005 | 11:14 PM
gasitman's Avatar
so where do I get the whaite faced gauge cover for the instrament panel?
Old 03-05-2005 | 11:18 PM
doodah's Avatar
-Just make sure it is for a auto or maual too! I got mine from a guy that had a 5-speed, and it was made for a auto, $20.00 on the pillar pod, I took my factory one off, the prevoius owner of the pod had a hole in the top side just above the top pod, and I used this also, just took my factory one off, pt this one on, and put a scre with a plastic cap cover on it! looks fine, I just didn't want to drill into my stocker.
98silver12v
10-07-2007 11:18 PM
raw122
05-30-2007 08:06 AM
03CTDCO
06-13-2005 10:10 AM
ckennedy
10-07-2004 02:46 PM
thumper 549
09-07-2003 12:36 AM
