gauges and lift pump?
i got a edge comp on my 01 and i am wonderin wat the next step should be? put in gauges or a lift pump or fuel system of some kind? i here air dog and fass are both good. how big of a fuel system do i need if i was thinkin of addin 100 hp inj. sometime.
01 shorty straight pipe edge comp
On an '01 you probably should have done the guages before the box. I'd definitely get on with guages but the odds are you'll find out that your fuel pressure is low and need to upgrade your lift pump as well.
Good luck! Randy.
Good luck! Randy.
just bend over and spend the money on both the gauges and the pump...i put the airdog and the fass in the same quality cat...it's up to you on which one you get...IMO i'd get the filter setup, not just the pump...if i could go back i would...
BIG MEX
04-19-2010 12:17 PM
Kman9090
29
12-06-2007 06:43 PM
coontz0473
17
09-22-2006 03:52 PM
