Gauges
Gauges
:Friday I ordered gauges for my truck.A combo(turbo boost-<br>and exh temp) and trans temp from Genos.My guestion is on<br>the exh temp,I got the one-eights probe.I wont get them<br>for another 7 days or so,but what drill bit size will I need and<br>is there a picture showing exact spot to put it? I can hardly <br>wait till they get here so I thought I could get all needed bits<br>and what ever else I might need.I would apreciate any and<br>all advice on this for it is my first time doing this. <br> thank you
Re:Gauges
Hi there,
The usual hole size for the 1/8 is 21/64 and I usually try to get them in the back half to the manifold if you can get a small enough drill. If not try going in the back half of the turbo down spout ( this can put fillings into the turbo however if your not carefull) Thread with 1/8 NPT 27 But If your not sure on the size of the threads, wait till you get the probe, If your hole is to small thats okay, if your hole is to big, you have some work to do,( makes things very unpleasent) This is how we do it, But if someone our there has a better idea I am open to suggestions.
Thanks
Heath
Thanks
Heath
Re:Gauges
[quote author=Ram lon ON link=board=17;threadid=15922;start=0#149567 date=1055717241]
:... what drill bit size will I need and
and what ever else I might need. ...
thank you
[/quote]
1/8 NPT (1/8-27) uses a 21/64 drill
bit.
Here are some instructions with diagrams and measurements.
Install Gauges
thank you
[/quote]
bit.
Install Gauges
Re:Gauges
Just installed my EGT a couple of weeks ago. Used the tstproducts instructions. I used a 3/16 and a 5/16, rather than a 21/64 bit. Made the tapping a little more difficult, but I didn't have a 21/64. When drilling, I used a lot of grease on the bits and put magnets all around the drill on the exhaust manifold. Then I used a probing magnet to fish around in the manifold when I was done drilling and tapping. Took about 20-30 sweeps, but eventually nothing came up. Worked like a champ!
Good luck!
Good luck!
Re:Gauges
I put the Westach combo in about a month ago. Geno's gives you good instructions. I think I have a bad thermocouple. It fluctuates and sometimes doesn't work (reads zero). If you need to contact Geno's don't use the e-mail adress, just call. They read my e-mail and got a response a couple of days later. They asked me to call. I have got a replacement on the way now. They seem to be good people to deal with. Have fun installing, mine was pretty easy. No suprises.
Kman9090
29
12-06-2007 06:43 PM
coontz0473
17
09-22-2006 03:52 PM
estesbubba
07-18-2006 04:35 PM
AggiePhil
01-30-2005 01:15 PM
