gauges
Old 04-05-2008, 11:45 AM
HOHN's Avatar
Autometer replace my bad pyro for free-- and upgraded me to a NV series with the better lighting, even!
Even if their guages are just so-so, I'd buy them again because of the good customer service I received.
jmo
Old 04-05-2008, 12:24 PM
smokinstrokes99's Avatar
isspro are great and cheap as well. i had hell installing mine (maybe just unlucky) i would recommend paying someone to install them for you. i ran the fuel in to the gauge and by passed the isolator for a more reliable fuel pressure reading. i used vulcan and he was the cheapest but the lines and fittings were a poor quality.
Old 04-07-2008, 01:07 PM
flatbed beast's Avatar
Do i need a transmission temp gauge for a manual.
Old 04-07-2008, 01:16 PM
CODODGE2500MAN's Avatar
not necessarily....
If your manual is heating up all that much....you've got bigger problems.
I'd just go with a 3 pod with Pyro, Boost and FP.
Old 04-07-2008, 01:27 PM
Ok thats what i am going to do. Do you have any idea how i could wire those gauges into my power so they can be dimmed by the dimming switch on the truck. Also where does the fuel pressure gauge plug or tap into? thanks Sam.
Old 04-07-2008, 02:03 PM
not sure about the FP gauge, as I am having mine put in right now.
As for the dimming, tap the wire right at the switch for the lights.....not sure which one, but ATS put in my first set and it dims with the switch....I have a 98 though so I'm not sure, but I think its the same idea.
Old 04-07-2008, 05:36 PM
tap the fuse or the cup holder light (if a manual has one). search guage instal in the thread search,their are many pictures and coments that will help you out alot more than we can.
Old 04-07-2008, 07:41 PM
will do thanks
Old 04-08-2008, 01:40 PM
Lil Dog's Avatar
For a 12 Valve, the fuel pressure gauge is really not a big requirement unless you are running huge fuel.. The mechanical fuel pump is not a failure point as typical as the 24V engine. Pyro and Boost is good enough. If you are a heavy hauler with your deck, tranny temp wouldn't be so bad, or even rear diff temp if you want to get fancy..
Old 04-08-2008, 06:02 PM
Ok thanks i will pry just go with boost and egt for now. Any others i should worry about?
Old 04-08-2008, 06:45 PM
That will teach me to read all of the sig. for the original poster!!!!
You should be fine with those two gauges unless you want to get the diff and/or trans like suggested above.
Either way, you'll find yourself staring at the gauges, so remember.....watch the road every couple of seconds too
Old 04-08-2008, 10:21 PM
On a 1996 manual where does the transmission temp tap or plug into i am confused? pics or drawings are great if have any.
Old 04-08-2008, 11:07 PM
Lil Dog's Avatar
For the manual tranny you would have to tap the tranny cap plates for the PTO for mounting your sensor, bearing in mind not to hit the gears... The plates would be thick enough to tap the NPT thread for the bushing for the sensor I would think.. If anyone has some pics, it would be good
Old 04-09-2008, 08:03 AM
high bid's Avatar
Quad commander has worked well for me....4 readings on one screen
Old 04-09-2008, 05:48 PM
What exactly is the quad commander heard of them and would they work on a 1996 dodge.
Quick Reply: gauges
