Gauge Sensor Dope or Tape Recommendations?
Just got a two Westach combo guages (Pyro/Boost and FP/Trans Temp.). To install the gauge sensors what type of thread dope or tape should I use on the threads?<br><br>EGT Sensor?<br>Boost?<br>Fuel Pressure Sensor?<br>Trans Temperature Sensor?<br><br>Thanks in advance for any help!
Administrator / Scooter Bum
Re:Gauge Sensor Dope or Tape Recommendations?
I used TFE pipe dope on my liquid connections(fuel, ATF).
Just enough to fill the threads, none on the sealing surfaces of AN connectors.
None on the boost connections.
Anti-sieze on the Pyro/Thermocouple.
Stay away from the tape.
(doesn't allow good ground connections, pieces can break off and get into the VP injection pump or Valve Body)
rshelton88
01-21-2003 05:33 PM
NWDave
18
12-30-2002 07:56 PM
