gauge question
Old 04-15-2008 | 02:39 PM
Dinner's Avatar
For the exhaust manifold, I drilled slowly but would add grease every now and then so most of the shavings would stick to that. Once I had my hole drilled through, I took a magnet and moved it around in the manifold which helped bring some more out. After that I installed my Pyro probe and started it up.
Old 04-15-2008 | 03:02 PM
Busboy's Avatar
Small magnet if you have one but I've done a couple in situ and just left them to blow through with no problems.
Old 04-15-2008 | 03:34 PM
flatbed beast's Avatar
ok figured I would do that thanks
Old 04-15-2008 | 03:50 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
Drilling and tapping the exhaust manifold with it on is ok (tho i do prefer to remove myself). But I really wouldn't with the intake on. Any of those metal filings can cause damage to your valve's seats and guides. JMO
Old 04-15-2008 | 10:26 PM
Yeah i will do that it will be eaiser i think to.
What about the transmission i got lost trying to put my sender in to day. It is a manual so i have no clue where it goes any ideas?
Old 04-16-2008 | 10:37 AM
TOM R's Avatar
I drilled most of the way through with a big magnet that had a hole in the center then when almost through started the truck, i also ran the tap in with her runnin
Old 04-17-2008 | 03:14 PM
Do I have to tap anything.
Old 04-17-2008 | 03:30 PM
JPR Ram's Avatar
I've never heard of any one installing a temperature gauge into a Dodge Ram manual tranny. That may be why no one has responded to your question. I'm sure it can be done, I just don't think it's necessary.
Old 04-17-2008 | 08:16 PM
Thats what I have heard. Any ideas what i could replace it with i got a tranny temp, a boost and a pyro with the 3 gauge pillar for free. So i need to repalce it with something.
Old 04-17-2008 | 08:22 PM
JPR Ram's Avatar
Maybe another boost gauge to read your drive pressure (pre-turbo pressure)? Or a Fuel pressure gauge? Or a rear axle temp gauge?
Old 04-17-2008 | 11:08 PM
I am thinking of doing an outside temp. any one done this.
Old 04-23-2008 | 10:19 PM
Is there an electric fuel pressure gauge or all of them mechanical? And if so where does the sender go?
Old 04-23-2008 | 11:37 PM
CODODGE2500MAN's Avatar
The electric fp gauges are a little bit more pricey. The best place to put the sender if you are using the stock fuel lines is a banjo bolt I believe. I could be wrong. Mine is in the line from the FASS to the VP44, but if you have the stock fuel pump, just use a banjo bolt I believe
Old 04-24-2008 | 12:03 AM
JPR Ram's Avatar
Personally I don't think electric senders are very good. As for mechanical gauges, yeah there is a banjo bolt that allows you to connect a compression fitting and plastic tubing.
On a side note: hey CODODGE2500MAN - did you ever get your torque converter lockup switch installed?
Old 04-24-2008 | 03:38 PM
Yeah but where does the electric sender go? On the electric gauge.
