Gauge pods revisited!
Old 10-31-2007 | 03:20 PM
pull-do's Avatar
Anybody know if there is a 3 gauge pod available w/tweeter that is a replacement fit and not a "fit over"-------my gauge kit came with the fit over pod and it is a POS in my opinion. No way can I figure out how to get it to fit snug over the existing pillar, the OE tweeter speaker hole holds the replacement pillar out.
Wish I would have bought my kit from Diesel Manor since it comes with instructions, mine is, well, here it is and good luck. ISSPRO gauges, just no instructions with the gauges or pillar.
First I have to get a A- Pillar worth a flip, that's why I would like to have a replacement fit pillar instead of the "fit over".
Thanks, just frustrated with some of the vendors.
Old 10-31-2007 | 03:27 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
Ummmm, you need to trim (ie cut) the stock piller to make the 3 pod pillar fit properly. I had to pretty much trim the whole tweeter pod off of the stock pillar.
Old 10-31-2007 | 03:29 PM
Dr. Evil's Avatar
They are all "fit over" - theres no such thing as a "replacement fit"...you have to cut out the tweeter hole on your factory A pillar.
Alternatively, you can install your aftermarket A pillar without using the factory one...but as youve already found out, its not easy to get it right.
Old 10-31-2007 | 03:36 PM
pull-do's Avatar
What I figured also, but the vendor told me this was not the case, I just ain't doing it right, should fit.
Old 10-31-2007 | 03:44 PM
JPR Ram's Avatar
HUH....... I could agree with that if there was NO stock tweeter pod. But with a stock treeter pod, I really just don't see how it would fit with out some cutting.
Old 11-01-2007 | 11:24 PM
hink's Avatar
I ordered my kit from Diesel Manor, you have to trim your factory A-pillar with that one too. They're all the same. I left my factory A-pillar off and stuck the gauge pillar down in the dash and then put a small screw at the top. Yeah, you got a screw there, but it saved me from having to cut up my factory pillar. The rubber trim around the dash at the bottom of the gauge pillar holds it firmly and the screw holds it at the top. I put a little black paint on the screw so it didn't stand out as much. Looks pretty good and didn't have to destroy my factory A-pillar.
Old 11-02-2007 | 12:52 AM
Dr. Evil's Avatar
ok, but how did you make it fit tight against the windshield?
Mines the same way as yours and from what Ive seen you have to use the factory A-pillar to get a tight fot and to have it look right.
Old 11-02-2007 | 11:57 AM
lgp9999's Avatar
So even if you get a pillar pod with a speaker hole in it you still have to trim the stock pillar trim piece?
Old 11-02-2007 | 12:26 PM
Dr. Evil's Avatar
To make it fit properly - YES
Old 11-02-2007 | 09:36 PM
Rollink2's Avatar
I just installed the Autometer 2 hole with speaker. The instructions say to grind off the speaker mount on the stock pilar cover and put the new one over the stock cover. Not wanting to destroy my stock cover, I did this.
1) Removed the stock cover
2) Fitted the new cover on without the gauges in
3) Measured distance between the cover and A pliar (about 1")
4) Found some square plastic tube (about 1")
5) Cut 2 pieces about 2" long
6) Attach square plastic tube to A pilar with self tapping screws
7) Attach new pilar cover to plastic spacer tubes with velcro
8) Enjoy the way it looks great, fits tight with no rattles. Easily removed to changed burned out bulb.
Hope this helps Rollin
Old 11-02-2007 | 09:41 PM
OlBlue's Avatar
I went to the wrecking yard and got a pillar cover without the tweeter to install the gauge cover over. I used hard plastic epoxy to glue them together so there are no rivets showing. This way I also kept the original one in good shape.
Old 11-02-2007 | 09:54 PM
Dr. Evil's Avatar
Now thats thinking...
Old 11-03-2007 | 02:14 PM
Rollink2's Avatar
LOL It gets dark early here in CT , so lot's of garage time to solve these problems. Good excuse to stay off the sofa too...
koogala
15
05-04-2007 05:46 PM
MoparMarv
05-04-2006 05:41 PM
joking
09-08-2003 06:41 PM
FireNhole
02-25-2003 12:22 PM
