Gauge light hook up.
Looking for some insight on what wire to tap into for the lights in my brand spankin new gauges I installed. I would like to get into the dash light circuit so they can be dimmed. I found the fuse for the the dash lights on the drivers side of the dash but it's not easy getting directly to the fuse box. I thought it would be easier to tap into a wire coming out of the back of it but did not want to poke holes in all of them to find the right on. Thanks for any info!!
HydraulicGuy
HydraulicGuy
If I remeber correctly, I pulled the headlight switch on mine and tapped into the Tan (I think) wire and that dimmed with the dimmer switch. I run all three of my gauge lights from that and have had no trouble.
HTH
Jim
HTH
Jim
Use a fuse tap at the panel, "Illumination" fuse. No need to pull the switch and you have the dimmer function. The wire drops down really easy! I can send you pics, if you'd like?
I saw the illumination fuse in the panel. Can you get through the back side? I should have looked at it closer last night!!! I will take a closer look this evening.
Thanks!!!
Thanks!!!
If you look above the fuse panel, behind the plastic cover, you'll notice approximately 1/2" gap, which you can run your wire through. PM me your email address and I'll show you a pic of my install. I was like you; stressing over the darn light wire ... I laugh when I reflect!
ehill
04-20-2007 07:29 AM
electrifried
10-11-2006 04:37 PM
Filmhog
21
07-15-2004 09:59 PM
Dodgezilla
03-12-2003 01:50 PM
tomsauto
11-18-2002 07:22 PM
