gauge install question?
hey everyone new to the forums, so ill start off with hi . i just bought a 96 12v, and want to install boost, egt, trans. does anyone have any good links with pics of placement of egt prob and trans sensor, and boost hook up? i did a search but couldnt find what i was looking for thank anyone with help
For the tranny probe, I used the in-line adapter, purchased from Geno's Garage.
My pyro went into the tapped hole in my AST manifold, which my 96 needed, as its stock was shrunk already.
Boost went into a factory hole in the intake, but my truck's in Las Vegas right now, so I can't help with pictures yet.
Boost Port
Need to know the year of your truck for the tranny temp. If it's a '94-'95 you only need replace the stock sender with your new one then trick the computer into thinking the stock sender is still there with a 1000 ohm resistor jumped across the connector to the removed sender.
yeah, thats the one, you will screw the temperature sensor into the "T" a wire it to the gauge. just make sure to put it on the "hot" line from the trans. wanna see a pic?
alright, i guess you get to see the oily mess that is the bottom side of my engine. the "hot" line is the one most towards the front of the truck, the "T" from genos will have a picture of where to put it as well. hopefully this pic will help.
ado2b1
07-06-2007 10:27 PM
White02Sport
10-06-2002 07:11 PM
