Gauge Install
Gauge Install
I haven't recieved my new gauges to look at the install instructions but I seem to remember on several posts that to dim the gauges there is some kind of dimmer switch or something you need to buy. My question is, Why can't you wire it to the dimmer switch for the dash lights? Just wondering.
You can (and need to) there is not switch other than the one you ready have.
Some do recommend toning the bulbs down a bit by making a line across them with a sharpie marker. Other than that, grag a test light and have a buddy work the dimmer switch for you. I think your wire is orange/brown (think).
No big deal. Where'd you get the gauges?
I was going to get them from Mark at DPPI but my wife decided to get them for me for my b-day and she's getting them from Diesel Manor which is good also. I hear lots of great things about both of them.
Your wife did well my friend! (nothing against Mark of course).
You are going to be quite impressed with the set of directions that come form Diesel Manor. It's ridiculous how comprehensive and easy to follow they are.
I was more than satisfied with my gauges from them.
I am gonna get a set of Issopro gauges: pyro, boost. trans temp, fuel pressure. Do they come with all the necessary hardware and wiring harnesses or do i have to buy that stuff separately?? Also what is the the deal with the banjo bolts?? do they have something to do with the installation??
I have a set of Autometer C2 gauges and I wish I had a seperate dimmer for them, I am going to get a dimmer soon. Its hard to see out to make a left hand turn at night, the gauges are so bright on the A pillar that they blind you. I would highly recommend putting a dimmer on them to tone them down.
Right now I have mine hooked to my dash dimmer and with the dash lights turned all the way down the gauges are still glowing bright, they dim some but very little, I think it has to do with them being LED.
I don't know much about DiProcol gauges but if they are LED lit then you need a seperate dimmer. I would still hook them up to the dash dimmer, just hook another dimmer in the circuit.
Banjo bolts are what connects the hoses and lines of your fuel system. basicaly hollow bolts with some holes drilled in them to allow the fuel to flow through. They can be replaced with higher flowing fittings.
spooled142
03-19-2009 09:10 AM
ado2b1
07-06-2007 10:27 PM
AndyMan
05-11-2007 07:50 AM
QWKRTNU
09-26-2006 10:22 PM
