Gauge help!!
Gauge help!!
hey all, well im gettin gauges for my 99 dodge 2500. i want a full triple A-pillar pod w/ the tweeter hole. what do you think are the best gauges and most important to have? also any idea whho has the best prices??? THANKS
I got mine from diesel manor. They have a gauge "package". Comes w/ everything you need. My gauges are Isspro. Most important, imho, is fuel pressure, pyro, trans temp (auto), boost. I don't have the fuel pressure gauge yet, but it's on my list of things to do.
check out genos garage also. isspro/autometer cant go wrong with them. vp44 trucks need a fuel pressure/pyro/boost. trans is last imo only because your truck has a trans warning light in the dash that will come on if it gets to hot. just my opinion though
Well one thing that will make a difference is whether or not your truck is an auto, if it is it is HIGHLY recommended to get a Trans. temp gauge. Also highly recommended is a Fuel PSI for you 24v guys especially. EGT and Boost PSI are the standard "must-haves" though for any CTD. Check out PureDieselPower.com, the owner Garrett is an awesome guy to deal with and will get you set up with whatever you need for a good price. I very highly recommend him.
this is what i did....i went on ebay and found the gauge pod for a really good price.....then i went to summit racing and got the full sweep auto meter phantom 2 guages.....most important would be fuel pressure(if you have a first style 24 valve...99' to ....i cant remember), pyrometer, and transmission temp if you have a auto....since i dont have an auto and i dont have to worry about fuel pressure since i have a 12v...i decided to go with oil temp...and i put this in the port right above the filter so i can not only meter the exhaust going through the turbo, but i can also watch the oil temp going through the turbo....hope this helps!
-Nate-
-Nate-
Whats your guy's thoughts on Westachs stuff?
There on Genos Garage. I like I can get all four gauges into one triple A pillar pod with the dual trans temp/ EGT gauge. Money isnt a matter to me. I think its about $400 for all three gauges and the pod.
I also like the look since they kinda match the trucks interior.
They seem too have a good rep with the airplane folk and if they like Im sure theyd do just fine in a vehicle that hopefully never leaves the ground!
Just wondering about any thoughts. Thanks in advance.
Excellent EGT Thermocouple & Gauge Article
This is an excellent article. Worth the look before you buy gauges.
http://www.turbodieselregister.com/EGT_EVAL.pdf
jmccart
15
01-26-2008 09:32 PM
jmccart
01-26-2008 07:36 PM
Greeds22
25
09-11-2005 03:13 PM
engcogod
17
02-03-2005 08:49 PM
Patriot_RAM
10-08-2004 06:10 PM
