Gas Truck Gauges in Diesel truck
Old 12-14-2008 | 07:47 PM
Redliner's Avatar
Whos done it and whats all envolved to get them to work???? I have a 01 and would like to put a bigger tach in my truck for looks only......
Old 12-14-2008 | 08:27 PM
gwhammy's Avatar
I've seen it done in a pulling truck and everything worked.
Old 12-14-2008 | 09:25 PM
Tate's Avatar
Direct swap AFAIK, I'm trying to source a gauge cluster for my truck as well.
Old 12-15-2008 | 08:46 AM
Redliner's Avatar
So it should just plug in and work right??
Old 12-15-2008 | 10:40 AM
91rangerturbo's Avatar
I know my buddy put a gas cluster in his 2005 Dodge Cummins. It went right in and worked just fine. I don't know about the pre-03's. But i would say it's the same.
Old 12-15-2008 | 02:12 PM
Mike Holmen's Avatar
The Guru
You talking about aftermarket tachs. If you are, you would have to find a tach pick-up signal for you're new tach. The dodge is off a gear tooth and unless you can adjust the tach for the extra counts of teeth, it might not give you that acturate of engine rpm. You would have to do some frequency adjustments as the tach is looking for igntion cycles to function correctly. There are devices that you can plug into the OBDII port and record and display info from the ECM/PCM computer.
Old 12-15-2008 | 08:07 PM
Redliner's Avatar
No Im looking to take a stock gasser gauge cluster and put it into my truck. Dont want a seperate tach. Got to keep it looking as stock as possible so no one asks too many questions.
Old 12-15-2008 | 09:38 PM
The Guru
Just curious, how far are you planning on reving up the motor? What ya done to the motor? Let us know how it works for you. The stock should work. Just have to find the right connectors for the dash. dodge, does lots of switch on that stuff. You might have to find the same year dash as you're truck.
Old 12-15-2008 | 09:44 PM
haloman's Avatar
The cluster is a direct swap. The coolant temp will be off a little.
Old 12-16-2008 | 07:43 AM
Redliner's Avatar
how far off is a little?
Old 12-16-2008 | 11:34 PM
cumminsdriver635's Avatar
20 degrees if i remember right. I think the gasser one starts at 160* where the diesel one starts at 140*
Old 12-17-2008 | 07:54 AM
Redliner's Avatar
Cool thanks.
Old 12-17-2008 | 05:15 PM
haloman's Avatar
That is what I heard also.
Old 12-18-2008 | 02:23 PM
CaledoniaOutlaw's Avatar
won't you loose your wait to start light?
Old 12-19-2008 | 03:40 AM
Flatbed24v's Avatar
so what does this achieve, swaping diesel cluster for a gas one?
