Garrett turbo prices
Hotrod, you have pictures? I remember that your housing #'s was the same as mine. I just made a flange on mine and bolted it up. The garrett housing is only so large, unless he machines out the housing. Neat stuff. I would buy a stage 3 or one of these tweaked turbo. 110's aren't too big, but you need a decent sized turbo. You could go with a S300 series, I've never ran one. I'm impressed with mine vs my HX35 and HX40 experience. Mine spools-up fast and the egt's are too bad. Of course I run twins and its been years since I drove a single. I plan on getting a set of DDP 110's and see how well the rubber stays on my tires. Keep us in the loop on how good they work.
I've already tried the bigger sticks. I've used 250 DDPs and mach 6's. I want a clean towing set. Something that I can throw away the pyro and just enjoy the views when I'm towing. I've used 125 sized sticks. They work, but my coolant temps start to climb on the big hills. The jammer 4's aren't so good and my BD125 aren't too bad. I haven't tired that sized stick as of yet from DDP's. Also they say that you can get 2-3 mpg increase vs the stocker. At the price of fuel I can buy these and save some $$$ to.
egt's sink pretty fast with the box turned up haven't towed. i would like to try a twin setup but im not sure more hp is good for my foot as i got it sideways in 4th going through an s turn today on dry pavement.
I have not dynoed yet. Am wanting to very bad tho. I have not towed with the GT3788R & 120HP sticks. I did tow with the stage two with everything in my sig less the injectors and it was great!
Yep, you should be able to see the bolt holes just outside of the flange, unless he filled those in on yours. They are visible on my 3782 from him.
HOHN
60
04-02-2008 10:47 PM
smoke_pedal
15
12-15-2006 01:53 AM
Dusty Ratcliff
37
11-30-2006 06:21 PM
GlennRMK
05-09-2006 10:07 PM
