Gage Question
Old 03-19-2007 | 06:44 PM
mopower's Avatar
Gage Question
Hehe, posted this in the 3rd gen forums by mistake...this seems like a better place to get answers!
Got my gages this weekend, to put in with my fuel module. I picked the 3 gage unit on the dash since the pillar seemed too close to my head, and I like it, except for 2 things...the mounting is a little odd, since I have to leave the center gage loose so I can pull it out tot get to the mounting screw, and the cooby hole light wires I used for the lighting tap don't work with the gages. I tapped the cig lighter for the pyro hot and was just going to tie the lights into that too, unless there is a better suggestion. The gages are optix...pyro, boost and fuel pressure.
I also have a question about the fuel pressure mounting location. Whats the best place to tap in on a 12 valve? the 24 valvers and the instructions say to use the inner NPT port on the fuel filter, but mine isn't tapped. Shall I go ahead and tap it or is there somewhere else I should put it?
Old 03-19-2007 | 06:57 PM
wcbcruzer's Avatar
Drill and tap the banjo bolt. No one sells them pre-tapped for the 12v.
https://www.dieseltruckresource.com/...highlight=fuel
For the lights, I just hooked it up to a fuse.
Old 03-19-2007 | 07:25 PM
mopower's Avatar
Thanks! Nice Pics.
Is that the banjo bolt on the pump? Maybe there is only one...I'm still learning. I want to make sure I get a post filter reading so I know when the filter goes bad.
Also, if I pull that bolt will I need to reprime my pump, or can I just fire it up?
If it is the bolt on the pump, maybe I should just pull my plate while I'm at it and bust out the grinder...
Old 03-19-2007 | 07:57 PM
wcbcruzer's Avatar
Originally Posted by mopower
Thanks! Nice Pics.
Yes it is the banjo bolt on the pump. You don't need to prime anything. Just have to crank it a little longer once you put it back to get fuel back in the line (don't burn up your starter, give it a break in between).
1993CTD
05-20-2015 08:09 AM
redcad
12-06-2007 11:21 AM
mopower
03-19-2007 04:46 PM
hanko
02-17-2003 07:59 PM
Quick Reply: Gage Question
