Future Pulling Truck
Re:Future Pulling Truck
Well if you want to keep the 5spd you will need a bigger imput shaft. You would be better off going to a 6spd but it is A LOT more $$$$.<br>DM01
Drop it off @ www.EnterpriseEngine.com with a blank check and watch Dave ;D REALLY big! <br><br>
1) Build it yourself....a lot more fun....and you learn something to boot!<br><br>2) Go pull it once stock and see how it does! <br><br>3) Run the tranny until you shear the input shaft off!<br><br>4) Get a dual disc clutch......and Twin turbos......and a lot of fuel!<br><br><br>There is a rough guide......not to be followed in numerical order!<br><br>Good luck!<br><br>Bill
For your first mod I would also suggest robbing a bank or winning the lottery. <br><br>Those pulling guys don't play very cheap. To be competitive you might as well drop down the 4K for a set of twins. :'(<br><br>Good Luck<br><br>By the way, in September I'm going to be hosting a huge truck pull here in Lanesville, IN. I'm sure if you would like to come give it a hook or talk to the big boys they will be here. 8)<br><br>DB
love to come up there again and hook the sled. Hopefully by then it will be running good. I'm taking donations ! First thing is to get the pump and injectors taken care of, then dual disc clutch from southbend. Then whatever else i can afford, hopefull twins or bigger single. Wes
[quote author=oldred97 link=board=7;threadid=11176;start=0#109543 date=1046315344]<br>Is peter offering a dual disk now?<br>[/quote]<br><br>There was [glow=red, 2, 300]little[/glow] talk of one a few months back but I think its still in the R&D dept. :<br><br>If [glow=green, 2, 300]I[/glow] were going to be building a "Pulling Truck" I would go straight to Enterprise Engine and get their dual disk clutch. Since its designed specifically for that purpose.
Guest
Posts: n/a
[quote author=BigBlue link=board=7;threadid=11176;start=0#109599 date=1046322272]<br>I'd swap in an 8.3 Cummins and mod it. Make for a helluva pulling engine.<br>[/quote]<br><br>The B5.9 is capable of 1000+hp when properly setup. So, the C8.3 would be a waste of money.
Also the 8.3C would not be aloud at certain pulls that require an engine that is supplied with a pickup for pickup pulls ie 5.9,7.3,6.6,6.5,6.9,6.0.<br><br>--Justin
Dodgeboy59,<br>You'll have fun with your pulling truck, it's easy to get hooked . I have a Mitchell billet input shaft (1 3/8" HD) for a 5 speed and a fully splined output shaft kit that I didn't use because I converted to a 6 speed. Could save you some $'s if you're interested. Larry
