Fuse for pyro amplifier box
Old 04-25-2005 | 01:31 PM
RenegadeT's Avatar
I'm installing Isspro EV gauges in my truck, and need some electrical help here. My pyro came with the signal amplifier box which needs a power feed. The directions say to use ignition-on power. I grounded the black wire to the dash chassis and ran the red one into the fuse panel, hot side of #16 (spare). I was thinking about it, and there is no fuse in here. What amp fuse should I run inline?
I've emailed Isspro, just wondering what everyone else has been doing. BTW, I'll post their reply when I hear back
Old 04-25-2005 | 02:47 PM
Shovelhead's Avatar
Administrator / Scooter Bum
I installed a Painless Wiring 7 circuit fuse panel (4 Hot with key ON - 3 constant Hot) to handle the load of my aftermarket accessories without resorting to 'tapping' existing fused circuits.
Old 04-25-2005 | 03:31 PM
RenegadeT's Avatar
Do you have a signal amplier box with your pyro...what size fuse did you go with?
Fuse #16 is open and un-used, so I took the easy path and used it
Old 04-25-2005 | 04:31 PM
Shovelhead's Avatar
My Isspro Pyro also uses an amplifier box.
I have it protected by a 20 amp fused circuit, hot with the key on.
Old 05-03-2005 | 08:08 AM
RenegadeT's Avatar
Just got this from ISSPRO:
"Normally these would be connected to a fused circuit. A 5 to 10 amp circuit would provide plenty of protection for the EV gauge amp box."
I've been running for a few days with the box connected to a 10A fuse in slot #16.
wcbcruzer
06-29-2007 02:27 AM
Wilson
03-02-2005 03:53 PM
JKM
02-28-2005 11:12 AM
TDIwyse
08-21-2004 01:24 AM
msurf
02-22-2004 12:50 PM
