funky fuel gauge??
funky fuel gauge??
my 95 cummins only shows 3/4 tank of fuel even though ive just filled it right up. what can be causing this? makes it kinda hard to plan fillups on long trips...wondering if this is a common issue or just me
Not bad. Just make sure the tank is low but you can take the bed off which is much easier. I did mine but my problem is in the electronics somewhere else so I just use my trip meter.
I didnt have access to an engine hoist or lift.. and no one around to help me lift the bed off the frame.
I emptied the tank into some jerry-cans with a pump and unhooked the filler and electricals. Then the straps.
I found that a pair of motorcycle lifts was perfect for this job.
stonewalldiesel
12-25-2003 09:04 AM
