full traction suspension system
Muted User
is anyone running this kit on there truck? they offer a 4in system including 2 new coils , upper and lower control arms, track bar brop, pitman arm, shocks, rear add a leaf, u bolts. seems to be a complete kit. i am waiting on a price...
Muted User
www.fulltraction.com ..... i did some more looking around over the weekend and i found a better system for cheaper price. i will post the link for ya if your interested...
You can tell in all of 10 seconds of looking that the Full Traction system is junk. Look at those cheap thin coils!! They are even worse than the SkyCrapper coils lots of us have!
Then look at the cheap $10 shocks they include.
Sorry to say, but if it doesn't use reservoir shocks, it's not high-end. Emulsion just can't cut it.
For "real" suspension, try KORE, Carli suspension, Desert Racing Concepts, Lorenz industries, DT ProFab, or some custom pieces from Thuren Fabrication.
JMO
JMO
Muted User
here is the link http://www.marketworks.com/storefron...113&i=60528266 ....from what i have read this is really not a bad kit...solid block for the rear as wide as the leaf pack, 5in coils up front for the cummins or v10...
Muted User
JMO
Originally Posted by scarecrow
i am not going to be useing my truck for off road at all...i have 2 other trucks that are built for trail use only..i just wanna add some height to it....
Scarecrow, by the looks of that kit it might ride better off road. If you're looking for additional ride height, you can get it there, but your truck will ride like on the street. The coil spacing and the add a leaf set up will rattle your teeth loose.
Since it does appear that you're after off road performance, what are you looking for? Just increased ride height or are you concered about ride quality at all?
Justin is right about one thing (in so many words), you get what you pay for.
Muted User
there not coil spacers..its a replacement 5 inch coil...and i would like to add 4 to 5 inches...ride quilaty is really not a major concern...i am use to trucks w/8,10,12 in springs so i am sure that tuff country kit will ride better than that...i like the price tag on the tuff country kit..plus it has the full replacement rear block and add a leaf so i can still put some weight in the bed if i need to..and from what i have read the track bar bracket is top notch....
Billut
03-01-2009 12:45 PM
LUKE-MM-PULLER
Competition / Pulls / OffRoad
07-13-2007 10:46 PM
darrenb
01-30-2007 07:01 AM
ron717
02-15-2004 07:58 PM
