Fueling Boxes
Fueling Boxes
O.K. Time for class to start again. .... I was looking at the Edge EZ. But had the priviladge of riding in a CTD with the Edge Drag Comp. And wooohooo what a ride! ;D.. I am considering the Edge Drag now. But what about the others? Can some of you "BOX FREAKS" give me some input? Here is a list of what my truck will be running.<br><br>1. DPP4" Exhuast (allready installed)<br>2. Scotty II W/ hole cut<br>3. Mach II Injectors ( soooon ) 8)<br>4. SBC (Not sure which one yet)<br>5. B1 Turbo (yes Rod, I will get one. ;D)<br><br>And of coarse the box, I have heard to many differant things about them all. Any input?<br>P.S. With the mod's I have mentioned above plus the box "YOU" recomend, what would be the est. H.P. and Torque??<br>Thanks GOINGBROKENOW! ;D
Re:Fueling Boxes
I like my Comp. Very easy to put on and off. The adjustable power/low boost smoke controls are real nice to. Plus, you can hook it up just like an EZ if you should so desire. The only difference between the the Edge Comp and the Edge DRAG Comp, is that the DRAG Comp will continue fueling up to redline where as the normal Comp defuels around 2800 or so.
Re:Fueling Boxes
Check out this web http://www.bluechipdiesel.com Chip was the first on the market and the only one with a paten on this third generation product. He has three generations of experience on fueling boxes I am sure he can fit your needs, Overfueled
Re:Fueling Boxes
I really like my TST PM3 Comp. I dunno how much HP it gives me, or how much it will give you, but I know it's good for lots of ;D.<br>Took my first GMC gasser this morning. Everything else on my truck is stock at this time, except for the Scotty II and upgraded fuel system you see in my sig.<br><br>Chris
Re:Fueling Boxes
The one Bully Dog has is from blue chip. Like most fueling boxes Blue chip started the whole thing. Some are a little more misleading than others. But in this case blue chip has given approval for BD to sell the FMS, not like some others on the market today. Overfueled
Re:Fueling Boxes
You can't beat the Edge Comp for the value it has. It adds roughly the same power as ANY other box, and is priced just right IMHO. <br><br>I would also have no problem with the TST PM3. I think that is also a great choice.<br><br>
t-boe
01-04-2007 08:35 AM
gsdog1
01-06-2004 04:27 PM
Gene007
11-02-2003 05:01 PM
John_P
24
07-13-2003 08:59 AM
