Fueling a B-1 on a 160 pump
Fueling a B-1 with a 160 pump
Well, after only a couple weeks and a couple hundred miles, I'm ready to take the B-1 off my 97 and go for broke, looking to pick up a 66/71/14 for it. I'd love to throw this thing on the 95 at some point. As it stands, I have a #6 plate, DDP 1 and 2 injectors, and my stock 181's that I could pull out, to put on my 95 for fuelling. The 2's were originally destined for the 97 for drivability, but after picking up the other truck, that's gone right out the window. I bought the 1's solely for economy, but would throw the 2's on in a heartbeat. Couple of buddies have already said they'd buy either set if I didn't use them. Anyways, will a #6, DDP 2's and 181's do it? I fuel it pretty good with the #11 plate in the 215 pump. Thanks in advance.
You will be fine, and if not, throw some 191 delivery valves in it, and call it good. The little 160's will really throw out some fuel with the right mods, so you will be fine i believe.
Eric
Eric
Jambbii
07-21-2004 11:05 AM
