Fuel from tank vent after FASS install?
Since putting the FASS system on 2 days ago, I now have fuel coming out of the vent tube on the tank. What can be causing this? I know the pump puts overflow back into the tank and it is building pressure, but I don't think it should be puking fuel. I'm not talking about a little bit, I mean when I stop enough runs/drips off to leave a 1' diameter spot.
I'm thinking maybe the filler cap? Is there anyway to check the cap to see if it's good?
ANY help would be appreciated a bunch.
Is it leaking at the tank vent or the filler cap?? Did you remove the old fuel line? Could it be leaking where the fuel and return lines connect?
Clean it off and crawl under and see why it's leaking.
Leaking from the tank vent. Old fuel line is still in place. just hit me. The old fuel line is connected to the LP which is connected to the stock filter which is FULL OF FUEL. I bet when I got on it, the fuel in the line rushed to the rear. I bet the vacuum created by that is sucking the fuel from the filter assembly. I feel like such a Homer, DOH... I will verify today. Still trying to find time to remove the stock filter assembly and LP.
Bluedeviltorque
06-28-2009 10:45 PM
53 willys
275
05-09-2009 12:20 PM
RDR
03-13-2008 08:02 PM
rjm022
09-30-2006 05:11 PM
cLAYH
04-21-2006 08:16 PM
