fuel system upgrade
Old 02-20-2012 | 09:54 AM
1dumrednek's Avatar
fuel system upgrade
i'm looking to upgrade my fuel system this spring/ summer. i already have the airdog fp 100. but its just sucking through a draw straw so i get low level slosh issues. im planning on getting the vulcan draw straw V so it would suck from the canister. while i have it apart i wanna do my return system too. i want to run 1/2 inch line for the whole return side. i'm wondering what size and where to get fittings to go from the banjo fitting on the back of the head to JIC (like the old airdogs came with for the supply side) and same for the return on the side of the vp44. then i'll have the return lines dumping into the canister so no slosh issues.
thanks
Old 02-20-2012 | 10:28 AM
New2Diesel's Avatar
"Gomer Pyle"
Call Richard Martin at Glacier Diesel. He always helps me out and is a mastermind at helping with fuel fittings and what not. He is not the only one but you can't beat his customer service on the subject.
Old 02-20-2012 | 10:34 AM
1dumrednek's Avatar
nice. they list those fittings right on their website. thanks. now just to figure out what size i need
Old 03-01-2012 | 11:36 PM
1dumrednek's Avatar
so 12mm on the back of the head from what i can find. and i need a barb banjo fitting for the return. 12mm also? am i right here?
Old 03-03-2012 | 07:23 PM
Mike Holmen's Avatar
The Guru
I run a 1/2in home made draw straw. I ripped off the fuel pick-up module suction screen and ran my 1/2in line in there. Been working for at least 160000miles, with no issues. Just make sure the pick-up module can travel fully into the bottom of the tank. I can run my fuel tank down to almost nothing. Hard braking will drain the fuel pressure down to almost nothing. I'm one of those guys that fuel regulate my injection pump at 55 psi of fuel pressure.
Had a few issues with the suction screen getting plugged up. Which protects the pump, but isn't a fun fix at -40 deg's F on the side of road.
Old 03-08-2012 | 11:15 AM
1dumrednek's Avatar
is 1/2" overkill for a return is is 3/8 plenty at 16 psi?
Old 03-09-2012 | 01:30 PM
1dumrednek's Avatar
also, if my truck is getting hard to start when the fuel level is down around half a tank, could that be the pressure relief on the vp44?
Old 03-13-2012 | 02:02 PM
jstone44720's Avatar
Probably a bit. The suction side needs to be larger to reduce velocity. The return side, being under pressure, can run a higher velocity, say maybe 4 or 5 times as much for a given flow rate. I just went through this on my 94 and have 3/8" ordered for the return line.
Old 03-15-2012 | 01:58 AM
The Guru
How much pressure you have during crank? How fast fuel pressure increase? You done any recent modifications like injectors? Any fuel leaks?
Old 03-18-2012 | 09:52 PM
1dumrednek's Avatar
no fuel leaks. no new mods. its 15-16 psi idling or cranking
Old 09-06-2012 | 08:52 PM
1dumrednek's Avatar
The hard start was a fuel leak. Banjo washer on back of head. Planning on doing the draw straw right away. Is it even worth going to 3/8 return out just leave it stock?
SilverRam01
07-24-2005 05:52 PM
Muzzy
05-03-2005 12:47 AM
caleb c.
04-19-2005 11:08 PM
Jack Thorpe
Site News
10-05-2003 02:17 PM
Jack Thorpe
25
09-11-2003 02:21 PM
